H22A swap promblems need help
Old Sep 5, 2006 | 03:51 PM
slammed95lude's Avatar
Default H22A swap promblems need help
Here is a list of my promblems
* Oil light flashes while driving
*Oil light is on at idle and car dies
* Trans feels weird like a whiring sound and you can feel it in the clutch
*No cooling fan...will not come on
*Ho2s is my code....I can fix that. Will it effect teh cars performance
*car seems like it is bogging
Old Sep 5, 2006 | 04:06 PM
prelude1897's Avatar
Default Re: H22A swap promblems need help (slammed95lude)
1) Do you have enough oil in the motor?
2) Did you hook up your oil sensor?
3) Did you change your clutch and flywheel to a lightend flywheel?
4) Did you make sure you fans were hooked up?
5) Is your O2 Sensor hooked up?
6) Just double check all the work you've done. You may just have some wires that need to be reconnected that you forgot to connect
Old Sep 5, 2006 | 06:39 PM
Default Re: H22A swap promblems need help (prelude1897)
I found out my buddy that was putting in the battery ground out the power while tightening it....I replaced those sensers so that only means the wiring or the ......ecu.
skippy33
Apr 23, 2014 03:21 AM
Jklango
Nov 13, 2012 05:00 PM
thaddeusiv
Apr 20, 2003 12:56 PM
chameleon
Feb 21, 2002 08:54 PM
