MY CAR ISN'T RUNNING RIGHT.
Old Sep 5, 2006 | 03:13 PM
racingcrx's Avatar
Default MY CAR ISN'T RUNNING RIGHT.
ok my setup is a b18a built 10.5:1 and stage 3 clutch, balanced blue print crank. I can't revv past 3k. and i was wondering do i need bigger fuel injectors? and it has been converted from dpfi to mpfi and i am using the stock fuel injectors. the starter is in the way of the lower radiator and it tore up 2 hoses already. what can i do about the radiator hose?
Old Sep 5, 2006 | 03:27 PM
racingcrx's Avatar
its a OBD-0 motor. with a LS OBD-0 ecu. the check engine light comes on when i start the car. and idle is about 2k.
Old Sep 5, 2006 | 03:35 PM
charlee's Avatar
Default Re: (racingcrx)
like it has been said a lot of time. check the ecu codes to trouble shoot the problem from there. if it has no codes then let us know.
Old Sep 5, 2006 | 03:55 PM
racingcrx's Avatar
Default Re: (charlee)
the ecu code flashes 4 times. and i think its the IACV
Old Sep 5, 2006 | 04:46 PM
racingcrx's Avatar
NEED HELP
Old Sep 5, 2006 | 05:04 PM
Suck my DX's Avatar
fix your codes and your good to go
what codes u throwin...im sure we can help you out
Old Sep 5, 2006 | 05:20 PM
racingcrx's Avatar
its throwing a code 4 on the ecu and when the car is started the check engine light comes on.
Old Sep 5, 2006 | 06:44 PM
racingcrx's Avatar
ANYONE?
Old Sep 5, 2006 | 08:30 PM
charlee's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">fix your codes and your good to go
what codes u throwin...im sure we can help you out</TD></TR></TABLE>
Old Sep 6, 2006 | 10:22 AM
4gencivicef9's Avatar
code4= cylinder position sensor swap the wires aroundat the dizzy or at the ecu, and you should be able to rev past 3k... I had the same problem with my b16....
look up b16 swap wiring and it will tell you on the pinouts whats wires are the cylinder pos.
pr3 ecu, I think it is c10 and c12, not sure cant remember, search button...
Old Sep 6, 2006 | 01:10 PM
racingcrx's Avatar
ok i'll try that. but about my radiator hose problem. the rear radiator housing touches the starter. and the starter rips my radiator hose up. what can i do to prevent it from happening.
Old Sep 6, 2006 | 01:23 PM
charlee's Avatar
what do you mean by the rear radiator housing?
Old Sep 6, 2006 | 01:28 PM
racingcrx's Avatar
yes. my starter touches it and when i get the hose on the starter rubs against it and it makes a hole and radiator fluid leaks out
Old Sep 6, 2006 | 04:29 PM
racingcrx's Avatar
the rear thermostat that is next to the starter rubs on my radiator hose and i need help to figure this out so i don't have the go through so many hoses. thanks
Old Sep 6, 2006 | 04:42 PM
thesmogman's Avatar
Cut off a piece of hose from a bad one and wrap it around your problem area.
Zip ties, glue, 100mph tape
Or are you looking to get the correct hose that will route around it?
Old Sep 6, 2006 | 04:49 PM
racingcrx's Avatar
ok heres the problem. when the hose is not put on yet. the starter touches the thermostat and i can't even get the hose on and i have to pull the starter off to put it on then i can't get the starter on. and when i get th estarter on with the radiator hose there. i drive out and then radiator fluid leaks from there and its pissin me off. and i was wondering what thermostat housing do you guys use?
punkracer
12
Nov 2, 2006 04:09 PM
urquidezj
11
May 2, 2005 12:18 PM
jel002
Jul 20, 2004 12:17 PM
Chris_Bye
Jul 10, 2004 12:10 PM
