clutchnet stage 2
Old Apr 28, 2002 | 05:38 PM
808eg6's Avatar
Default clutchnet stage 2
any of you all using it. just installed mine yesterday and pedal pressure is very soft and grabs quite high. it also chatters a whole **** load. is all this normal.
Old Apr 28, 2002 | 05:56 PM
ALF's Avatar
ALF
Default Re: clutchnet stage 2 (808eg6)
The chattering is normal. It may or may not go away after break-in. As for pedal pressure and high engagement point, try bleeding out the system more. If that doesn't work, one of your cylinders may need to be replaced. Check for leaks around the master and slave cylinders.
Old Apr 28, 2002 | 06:41 PM
infuryum's Avatar
Default Re:
I had it. The chattering is normal. Bleed the system like he said and the pedal feel will improve and some of the chattering will go away. That is a beast of a clutch, though.
Old Apr 28, 2002 | 07:42 PM
IN VTEC's Avatar
Even my full-faced ACT HD-SS chattered during break-in. It just wants to be a lot grabbier when new, so it engages really suddenly without leaving you a lot of room to compensate with the gas.
Bleed the clutch fluid...that should help it feel better.
FlewByU352
Transmission & Drivetrain
May 1, 2013 03:09 PM
Rickcrx
Apr 5, 2010 02:08 PM
Rickcrx
Mar 11, 2010 04:30 PM
deeweezy187
Apr 16, 2008 09:56 AM
boosted350z
Dec 5, 2004 06:07 PM
