radiator core support replacement help
Old Sep 5, 2006 | 03:00 PM
quicksilver1689's Avatar
i ♥ snails
Default radiator core support replacement help
I searched and found one thread with a little info. The task im trying too accomplish is changing out my radiator core support. the vehicle is an EK 96 sedan. The current core support is thrashed n trashed bent too hell. I read there is about 40 spot welds ill have too drill out. That is about the only information i found. What else is there too do? Im pretty handy when it comes too fabbing stuff. I have a lincoln 135 mig welder in my garage, will that be enough for the job or do you guys reccomend tigging it? Anybody who has helped or done this job there self please chime in. Thanks
Old Sep 5, 2006 | 03:02 PM
Miracle's Avatar
Default Re: radiator core support replacement help (quicksilver1689)
If I am not mistaking there are a couple bolts that need to be removed, like it was on mine. But other than that, just drilling out the tack welds is the biggest job.
Old Sep 5, 2006 | 03:11 PM
i ♥ snails
word, were can i source a new radiator cor support? and also how was the welding process? do you just retack it?
Old Sep 5, 2006 | 03:15 PM
Miracle's Avatar
Default Re: (quicksilver1689)
http://www.hondaautomotiveparts.com will be able to get you a core for next to nothing I am sure.
All you have to do is bolt the support in, and make sure everything lines up with the body panels hung. If everything matches, then you spot ( TIG preferabally)weld where the OEM one was.
EDIT: that website lists a new front bulkhead assembly for $166 and some change. The set is listed as #13 in the diagram below.
Old Sep 5, 2006 | 03:26 PM
i ♥ snails
Sweet deal, yeah i saw some on ebay but im doubting there gonna fit like oem and be as strong. One last question can i mig weld them? i consider my self too be a competent welder. thanks for ur help and not bein a dick like 98% of ht members.
Old Sep 5, 2006 | 03:32 PM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quicksilver1689 &raquo;</TD></TR><TR><TD CLASS="quote">One last question can i mig weld them? i consider my self too be a competent welder.</TD></TR></TABLE>
The only real welding experience I have is with TIG. So I am not sure on that one. You will have to get with somebody that knows a little more about welding theory and practice that I do.
But yeah, go with OEM man. You can't go wrong with it. And you know it will fit right.
Old Sep 5, 2006 | 08:35 PM
i ♥ snails
Anybody give me some more information on the welding process?
Old Sep 7, 2006 | 07:13 AM
i ♥ snails
bump
Old Sep 7, 2006 | 07:27 AM
Phillyhatch's Avatar
mig will be fine. just follow all the factory welds and it will be just as strong as it came from the factory. Just grind your welds for a clean finish. also may want to pick up some weld-through primer. Then just primer and paint and your done
Old Sep 7, 2006 | 04:57 PM
i ♥ snails
word thanks for the input !
Old Sep 21, 2006 | 05:25 PM
i ♥ snails
bump, anybody else done a coresupport swap? howd the project go?
angrysmileyface
Mar 26, 2018 03:19 PM
JDM EJ1 95
Dec 28, 2004 10:39 AM
B18CYAAA
Jul 14, 2003 03:22 PM
