4g pass airbag question
Old Sep 5, 2006 | 02:35 PM
logicdc's Avatar
Default 4g pass airbag question
I have a 92 Si that I will doing a dash swap on, so I thought "why not add in the pass airbag?"
What would be involved? srs controller, harnesses, pass airbag from donor prelude?
TIA
Old Sep 6, 2006 | 04:53 PM
logicdc's Avatar
Default Re: 4g pass airbag question (logicdc)
ttt
Old Sep 6, 2006 | 08:16 PM
Silver Surfer's Avatar
most everyone here would rather not have them so you probably won't get much info
and remember these are the first gen srs, so they don't have the delay on the deploy and caused more injuries in crashes than the new generation air bag does
Old Sep 7, 2006 | 11:15 AM
logicdc's Avatar
Default Re: (Silver Surfer)
thanks for the reply
Old Sep 7, 2006 | 11:50 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logicdc &raquo;</TD></TR><TR><TD CLASS="quote">I have a 92 Si that I will doing a dash swap on, so I thought "why not add in the pass airbag?"
TIA</TD></TR></TABLE>
yea in addition to either using the dash out of a prelude equipped with it, or just being very good at cutting holes in the dash to put it in, there is also a bit of bracketry involved, it mounts to the thick metal support that runs behind the dash, and i'm not sure the mounts would be there on a car in which it did not come originally equipped, nor do i think that this bracket would be an easy swap....
good luck with it though, if you do it contact your insurance company and maybe they will give you a discount for it
Old Sep 7, 2006 | 03:29 PM
logicdc's Avatar
Default Re: 4g pass airbag question (mgags7)
Yeah - I was planning on using a dash from an appropriate car with pass airbag.
My car should have the holes to bolt that bracket into - right?
Worst case = I make a pocket for it and have extra storage - right?
CapnKrunch
Dec 11, 2007 10:02 PM
littlegreenb18
Oct 3, 2006 07:17 PM
whatala
Sep 17, 2006 07:26 PM
hatched91
Jun 7, 2005 08:33 PM
shocktech01
Apr 27, 2005 07:01 AM
