Left brake (tail) light does not light up
Old Sep 5, 2006 | 10:35 AM
spacefugitive's Avatar
Default Left brake (tail) light does not light up
I have a 1998 honda civic. My left brake (tail) does not light up when I hold down on the brakes. Tail lights on a 98 civic are divided into 2 units, one on the car main body and the other on the trunk, like this.
Now, left tail light (the one thats on the car) does not come on when I hold the brake, but it flashes when I lock the car (using the keyless entry system). The one thats on the trunk works perfectly.
Do you know whats causing the problem?
Old Sep 5, 2006 | 10:37 AM
CantThinkOfAScreenName's Avatar
Default Re: Left brake (tail) light does not light up (spacefugitive)
Check your bulb, if its a double filamint the part that lights up for the Brakes probably burnt out.
Old Sep 5, 2006 | 10:38 AM
Miracle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CantThinkOfAScreenName &raquo;</TD></TR><TR><TD CLASS="quote">Check your bulb, if its a double filamint the part that lights up for the Brakes probably burnt out.</TD></TR></TABLE>
x2. Beat me to it. But yes, this is correct. Probably just needs a new bulb.
Old Sep 5, 2006 | 10:40 AM
Default Re: Left brake (.Red.EM2)
Kewl thanks. I will try to replace the bulb today.
Do I need to pull out the whole tail light assembly to replace the bulb, or can I do it with it attached to the car?
enemy no1
Feb 17, 2014 04:31 PM
David Bromberg
Oct 2, 2012 09:41 AM
tgun08
Apr 1, 2008 07:28 AM
xjohnny817x
Aug 29, 2007 12:47 AM
Importn2oRacer
Aug 7, 2007 12:17 PM
