i want to lower the S but not sure if i should
hey guys i need help w/ my car i really want to lower it about 1.25-1.5 inches in the front to 1.5-2 inches in the rear but im not really sure what to purchase can anybody tell me what their set up is n how low it is front n rear....also im 1 of the unfortunate few that still have that front strut popping noise and idk if lowering my car would take that problem away or make it worse than it already is....please some feed back would help alot thanx.
tony
tony
check out tein s-tech they lower your car 1.5 and they are meant for use on the stock shocks abut its better to upgrade to koni yellows and if u want to spend a lil more money that just go for the coilovers
good luck
Kris
good luck
Kris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Z1iVTEC »</TD></TR><TR><TD CLASS="quote">if i get coilovers which would u recommend n would dropping my car affect the strut popping sound ?</TD></TR></TABLE>
if u get coilovers you dont have to worry about your struts popping because they replace the whole thing struts and springs
Tien SS-p
Eibach Pro-Street-S Coilovers
Megan coilovers ar supposed to be good
the good thing about these is the fact that you can adjust them to any height thats right for you.
Tien SS-p
just wondering what year is your car??? because if u have the k20z1 that u should have an 05-06 which means you still have warrenty so just take it to the dealer and have tham fix it??? Correct me if im wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20Z1iVTEC »</TD></TR><TR><TD CLASS="quote">hey guys i need help w/ my car i really want to lower it about 1.25-1.5 inches in the front to 1.5-2 inches in the rear but im not really sure what to purchase can anybody tell me what their set up is n how low it is front n rear....also im 1 of the unfortunate few that still have that front strut popping noise and idk if lowering my car would take that problem away or make it worse than it already is....please some feed back would help alot thanx.
tony</TD></TR></TABLE>
fix the problem and slam that biatch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepin02rsx »</TD></TR><TR><TD CLASS="quote">
Slamming an RSX = zero suspension travel. Not a very good situation.
</TD></TR></TABLE>Slamming an RSX = zero suspension travel. Not a very good situation.
I'm just went to Yellow's with S.Techs. It actually created the popping sound when I made the switch, and switching back to stock didn't fix it. Overall I like the ride, and the drop is EXACTLY where I want it. The gaps on either side of the wheel are ugly, but it's better than having the crazy 4" gap on top
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 SICK 2 ERIC »</TD></TR><TR><TD CLASS="quote">here's my homie'z DC5 frum 5SICK2....
hella low
</TD></TR></TABLE>hella low
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">
Slamming an RSX = zero suspension travel. Not a very good situation.</TD></TR></TABLE>
exactly......
i would not go lower than 1" to 1.25...... any lower can have adverse effects on a strut suspension
exactly......
Suspension travel, both in the front and rear, is extremely poor with the RSX/EP3/01-05 Civic.
That red RSX has got to ride like a piece of crap. I don't care how much you spend on coilovers, there is no fixing the oem Honda geometry.
Koni Yellows and Tein S-tech is about the sweetest setup you can have for a daily driver/part time autox car.
Take two equal coilovers...slam one car (2.5" or more) and give the other one about 1.5" of lowering, and the 1.5" lowered car will handle so much better than the 2.5"+ lowered car.
Function before form IMO.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">Suspension travel, both in the front and rear, is extremely poor with the RSX/EP3/01-05 Civic.
Function before form IMO.</TD></TR></TABLE>
it has pretty good shock travel...rides like a champion....no bottoming out!!!!
i was thinking of getting the skunk 2 coilovers any have these....also they only have a rear camber kit for it do i not also need a front camber kit or not?
Modified by K20Z1iVTEC at 9:19 AM 9/10/2006
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 25Type-s »</TD></TR><TR><TD CLASS="quote">check out tein s-tech they lower your car 1.5 and they are meant for use on the stock shocks abut its better to upgrade to koni yellows and if u want to spend a lil more money that just go for the coilovers
good luck
Kris </TD></TR></TABLE>
Is this true? Meant for use with stock shocks?
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 SICK 2 ERIC »</TD></TR><TR><TD CLASS="quote">HAVE YOU EVER HEARD OF PROGRESS COMPETITION FULL COILOVER???
DO YOUR RESEARCH BEFORE YOU JUDGE HOW THEY RIDE ...
there is no research needed in what he is saying...... you can look at the pictures and tell that there is not sufficent suspension travel......
regardless of the quality of the componet.....
</TD></TR></TABLE>there is no research needed in what he is saying...... you can look at the pictures and tell that there is not sufficent suspension travel......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 »</TD></TR><TR><TD CLASS="quote">
regardless of the quality of the componet.....</TD></TR></TABLE>
IF YOU WERE FROM HERE ...MY HOMIE WILL GLADELY TAKE YOU ON A RIDE AN PROVE IT TO YOU....IT HAZ PLENTY OF SHOCK TRAVEL AND IT DOESNT BOTTOM OUT!!! I KNO FOR A FACT CUZ I RODE IN IT PLENTY OF TIME!!!
Some of you guys are being straight-up ********; I don't think that it's a coincidence that the ******** are the ones that can't spell, either.
If you want to drive a car that's slammed to the ground, get an old Impala or a minitruck. They're not out of character when they handle like ****. You've got a ******' RSX -- it's meant for driving, not putzing down the boulevard.
The picture above with the chicken-scratch "Gaps = teh l4ME" only demonstrates that using a flash always makes dirty wheel wells look like ****.
