ls swap options
Old Sep 5, 2006 | 08:36 AM
ek4ferrio's Avatar
Default ls swap options
im about to go and get my 96ls swap in and i was wondering what ways u guys would go about seting up ur ls like what r some disadvantages of ls vtec or ls turbo and if i wanted to upgrade the exhaust system would i have to go get a custom fit one cause i have a 96 4dr so im not to sure about that but any help would be good or jus any thing on jus keeping the engine the way it is except for the minor upgrades to the head or what not thank you!!!!!!!!!!!!1
Old Sep 5, 2006 | 09:01 AM
PhatBoy5015's Avatar
Default Re: ls swap options (ek4ferrio)
Sorry, retype that into different sentences. Also, use punctuation. That **** is hard to read.
Old Sep 5, 2006 | 10:06 AM
leeminho86's Avatar
Not sure what you mean by disadvantages for either set ups...both are fun and reliable if done correctly. If you want to upgrade the exhaust you just buy an exhaust made for your 96 4dr. Other upgrades are all up to you...what kind of tranny you running? Definetely a lot of options with this motor...can run 300hp on stock internals if you want to boost, one of my buddies decided to do ls/vtec with boost and dyno'd 357whp, one of the best upgrades you can do is if you're running an ls tranny swap it with a b16 or gsr tranny. Whatever you decide good luck and have fun
Old Sep 5, 2006 | 06:44 PM
ek4ferrio's Avatar
Default Re: ls swap options (leeminho86)
u said i can go and get a bolt on kit would it be different because if i got a full exhaust wouldnt that only fit for the d series thats in it or it wouldnt matter
Old Sep 5, 2006 | 06:47 PM
Syndacate's Avatar
The LS/VTEC's a nice, solid motor IMO.
My friend just made an LS/Turbo. Fully built bottom end (forged rods, pistons, etc.), more aggressive cam shafts (not sure what other head work was done). Not sure what he has the PSI on the wastegate set at but it's gonna get a good tune and it's probably going to be a good motor.
Advantages. Lots of torque for a honda motor (because of larger displacement (1.8) + turbo).
I'd say it'd be good for 250+whp w/ a good exhaust system & tune.
Old Sep 6, 2006 | 10:14 AM
leeminho86's Avatar
If you got a full exhaust I'm presuming it'd be a catback...and you'd want it for your 96 4dr so the piping would be properly bent. The header is the only thing you'd get differently...to match up to your ls motor rather d series.
noodlez1390
Jul 3, 2008 12:43 PM
CherryBomb1
Mar 29, 2004 07:20 AM
jbell
Feb 6, 2004 01:43 PM
