opinions on itr bar and beaks kit for EK chassis
Old Sep 4, 2006 | 10:09 PM
confucioussae's Avatar
Default opinions on itr bar and beaks kit for EK chassis
i know that just about everyone will recommend the ASR or comptech reinforcement bar, but i want to know if anyone is running a larger sized sway bar (~22mm) with a beaks kit on the EK subframe ? has anyone run into or heard about tearing problems WITH the beaks kit installed ??
btw i'm not autoxing or anything.. just driving hard in and out of the mountainsss every now and then
Old Sep 4, 2006 | 10:12 PM
cambopheonix56's Avatar
Default Re: opinions on itr bar and beaks kit for EK chassis (confucioussae)
Yes I have seen the damage with the beaks kit. Stick with ASR.
Old Sep 4, 2006 | 10:20 PM
sol2hatch's Avatar
i heard beaks kit is a pain in the *** to install, and have also heard that it is not that great a kit. get an ASR kit
Old Sep 4, 2006 | 10:31 PM
instrument's Avatar
search beaks and tear out, there were some pictures on here a few months ago.
Default Re: opinions on itr bar and beaks kit for EK chassis (sol2hatch)
no one can vouch for the beaks/22mm itr setup?
Old Sep 4, 2006 | 10:40 PM
IM ALL BOB's Avatar
Well the beaks kit does work, but you must run a spring rate of 350lbs+ in the rear, which of course will make your care pretty stiff on bumps and road surfaces. the reason the tear outs happen is because of the soft suspensions that most people run, that causes the rear subframe to flex with the swaybar, thus causing the tear outs that many people have seen. I have ran the Beaks kit with ITR rear sway bar on my 98 civic hb for 3+yrs and numerous HPDEs. good luck
Old Sep 4, 2006 | 10:49 PM
Default Re: opinions on itr bar and beaks kit for EK chassis (IM ALL BOB)
i don't know my spring rates, but i have neuspeed 'sport' springs with gr-2 shocks... would that work ? which springs are you usingg bob ?
Old Sep 4, 2006 | 11:11 PM
IM ALL BOB's Avatar
I am running Buddy Club Racing spec suspension that I modified and am running 350lbs front 450lbs rear. But the sport spring rate will just not be stiff enough for that swaybar. I say maybe go with a 19mm from eibach/neuspeed good luck
Old Sep 4, 2006 | 11:13 PM
coool, thanks bob
anyone else
Old Sep 5, 2006 | 05:04 AM
rmcdaniels's Avatar
I ran a Beaks kit with a 24mm Mugen bar with no problems. I tracked the car for a couple of years, autocross and road course, with Skunk2 coilovers (don't remember the rates, but they were pretty stiff) over Koni yellows. I also daily drove the car. It was an EM1, but that should be the same (or even thinner) subframe than an EK.
confucioussae
Suspension & Brakes
Sep 13, 2006 03:03 PM
1clean00EM1
Suspension & Brakes
10
Oct 16, 2005 07:22 PM
1clean00EM1
Oct 9, 2005 01:42 PM
gabebauman
Suspension & Brakes
15
Aug 1, 2005 11:02 PM
BanEL
May 15, 2003 08:51 PM
