RPM Services 72-70mm TB and IB ITR IM questions...
Old Sep 4, 2006 | 08:37 PM
GO-FIGHT-KILL's Avatar
Default RPM Services 72-70mm TB and IB ITR IM questions...
(I searched quite extensively, if this topic has already been covered, I apologize.)
I'm about to order my Import Builders Type-R Intake Manifold, and RPM Services 72-70mm Throttle Body. I'm installing these parts on my ITR.
I've been researching the RPM Services TBs, and it seems like a LOT of people are having problems with sticking, strange/sparatic idle, and RPM jumping up after warm up. Does anyone know what is causing this? Is there anything I can do to prevent these problems from occuring?
Anything else you guys can tell me before I install these parts?
Thanks in advance,
Old Sep 4, 2006 | 08:40 PM
Jimmy's Avatar
Global Moderator
I'm running the RPM 70 mm throttle body on my victor X and i didn't run into to any issues..
Old Sep 4, 2006 | 08:53 PM
Did you see pretty good power gains from that setup? I've heard it will top most ITB setups.
Thanks for the input.
Old Sep 4, 2006 | 08:59 PM
Jimmy's Avatar
Global Moderator
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">Did you see pretty good power gains from that setup? I've heard it will top most ITB setups.
Thanks for the input.</TD></TR></TABLE>
Still have yet to hit the dyno, As soon as do if i have impressive numbers they will most definetly be posted
Old Sep 4, 2006 | 09:06 PM
Haha, sounds good.
But did you FEEL any difference? Or were multiple parts installed along with those at the same time?
SPR876-B18C1
Feb 3, 2013 03:01 PM
1fastEK9
May 9, 2008 07:11 AM
92prelude23
Mar 24, 2008 03:06 PM
EleanoR
Sep 10, 2007 01:41 PM
Boostage
Sep 29, 2004 12:10 PM
