Cold engine clutch noise.
Upon getting in my car to go to the gas station today, the engine was at it's "cold" temprature.
Upon pressing the clutch in, there was a slight squeak/squeal/whine as the pedal got close to the end of it's travel.
But when I got home to look at it, it did not do it while the engine was warmed up.
Now seeing as this clutch system is hydraulic instead of cable activated, what could be the issue. I know it is not the pedal itself, because the sound is coming from the inlet to the transmission where the release fork would be.
Any ideas?
Any ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean DM »</TD></TR><TR><TD CLASS="quote">mine did the same thing, i replaced the master clutch cylnder and it went away, but now its back.</TD></TR></TABLE>
So that was not the problem obviously. Any more ideas?
i have the same problem it only does it certain times but my clutch is still good someone told me you could bleed the clutch but im not sure about that.................but it hasnt been doing that for some time now.............
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tak1civic »</TD></TR><TR><TD CLASS="quote">i have the same problem it only does it certain times but my clutch is still good someone told me you could bleed the clutch but im not sure about that.................but it hasnt been doing that for some time now.............</TD></TR></TABLE>
Honda warranty FTMFW!!!!11!1!1
heres a link for all the tbs for 7th gens.
http://www.geocities.com/pfeif....html
02-002 is for the sqeaky clutch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rennen »</TD></TR><TR><TD CLASS="quote">all 7th gens are basically the same. u can do it yourself. you just need to grease it up...</TD></TR></TABLE>
Nah. That is what the warranty is for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">
Thank god it's not just mine that does it! Only occaisionally though...
But then my EJ6 and EJ9 did it too, and a lot worse than my EM2.
Teg44
Nov 21, 2002 08:53 AM
