lc-1 wideband, p72 ecu
aight i just got myself a lc-1 wideband im i am a little confused on installing it. has anyone installed it with a p72 ecu? if so can someone tell me what wires i need to solder from the wideband into what wires on the ecu? thanks for all the help
The LC-1 should come with install directions straight from Innovate (if bought new).
Take the stereo plug for outputs, connect the wideband output to pin D14 on your ECU harness and ground the output ground in that same cable...
Well, Innovate's instructions arent going to be vehicle specific for tuning with Honda DIY Engine, management.
They will tell you about the two analog outputs though...send the wideband analog output to pin D14
