Oil pressure sender question
Looking for opinions of whether this will be ok or if it will break.
It's hard to tell, but the sender is mounted to a ge oil sandwich with a 90 and an extension. I tried using just the 90, but it hits the oil filter or the block.
Relocate it to the firewall. You can get stainless line in exact lengths from http://www.mcmaster.com or Flamenco-T just to name a few.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday »</TD></TR><TR><TD CLASS="quote">Eek.
Make a brace for it and brace it with the firewall.</TD></TR></TABLE>
it would snap off the first time you shifted since the motor moves in relation to the fire wall. a brace to the block would be fine but kind of bulky.
we have thick hi temp cooler lines at autozone in 5/16 or 3/8 diameter it sells for $ 1.50 a foot and route it to your fire wall i will try and take pics.
Don't forget to notch the msd coil bracket to fit the autometer sending unit. dremmel then bolt it up hope this helps
Modified by speedlabx2005 at 8:41 PM 9/4/2006
TravisBiggie
Apr 24, 2012 08:01 PM
Pompiuses
Sep 3, 2010 09:29 AM
