2 Subs + Amp - Which ones to buy?
Old Apr 28, 2002 | 03:01 PM
Understeer's Avatar
Default 2 Subs + Amp - Which ones to buy?
Keep in mind this would be under budget of <$1000 including install/wires/box.
1. What amp would be suffice to power two Alpine Type S 10" subs?
2. What other subs are in the price range of those, but maybe
better or cheaper?
Any other recommendations on what to get for a decent setup?
Old Apr 28, 2002 | 03:08 PM
ooostenb's Avatar
Default Re: 2 Subs + Amp - Which ones to buy? (Rated B)
a good MTX mono block amp would be great. they arnt too expensive and they kick the crap out most subs. i dont really know how much those type s's cost but look into JL audio. they make some great subs.
Old Apr 28, 2002 | 04:24 PM
89 CRX SI's Avatar
Default Re: 2 Subs + Amp - Which ones to buy? (ooostenb)
OK remeber this is cdn dollars. Ok for about 800 you can get:
concept dclass amp 1000 watts
2 pheonix gold dual voice coil 12" subs
4 gauge wire 15 ft
remote wire
RCA's
fuse holder
fuse
battery attachers
sub wire
3/4" mdf for making sub box
cocking
screws
and everything but the cd deck
Wire this to 1 ohm and itll pound. These are nice cause:
a. light
b. inexpensive
c. pound ***
d. look cool
e. use small air space so fitable
f. 3 year warrenty
Make your box with the correct airspace and do sealed boxes with these subs.
Goto andres electronics in burnaby and thell set you up.
Old Apr 28, 2002 | 07:57 PM
TexTeg's Avatar
His choice of Alpine Type S's is an excellent cost effective one that will pound out some of hte most accurate bass there is. I would not sway from it. If you want to save some money, get the MTX amp. An amp is an amp and honestly, you can't tell a difference between two of hte same wattage. Just some of hte cheaper ones will start to overheat, but not the MTX thunders. If those S's are dual voice coil, wire them into a 4 ohm load (wire the coils on the sub in parallel and then wire the subs in series) and then connect them to the bridge terminals of the mtx mono block. If they are single voice coil, run each sub straight to a channel on the mono block. Either way, that will thump and you will still have some padding in your wallet to buy whatever else you want.
Old Apr 29, 2002 | 07:50 AM
Malachi's Avatar
im selling my stuff, all in perfect condition. Kicker 12L5 in 2 ft^3 sealed box. 3/4" MDF. JBL 600.1 and 1 farad digital cap. Im looking for $300 US if you're interested. Dont need the weight in the new hatch.
Old Apr 30, 2002 | 06:13 AM
4gvtec's Avatar
Default Re: 2 Subs + Amp - Which ones to buy? (Malachi)
any heard of jl 10 w0-$160 for 2
mb quart dsd 216 6&1/2 componet set $275.00
eclipse is a great sounding mids and highs amp-around $145.00 have not been at the shop in a while.
also the eclipse speakers sound great for a really cheap price compaired to any thing in its price range....
the mtx i think its the 250 d class amp will work good on the jl12w0-have to find out price.
my friend owns a shop in florida
i help out in my off time.
he carries
jl audio
mtx
mb quart
eclipse authorized dealer.
Old Apr 30, 2002 | 03:26 PM
Thayne's Avatar
New User
Default Re: 2 Subs + Amp - Which ones to buy? (EFJAY)
Eclipse!
-Thayne
zsudz922
Audio / Security / Video
21
Oct 30, 2008 12:16 PM
SiR Inspired ED7
15
Apr 25, 2008 06:27 PM
E46Kid
Dec 28, 2006 07:22 PM
redline201
May 25, 2006 08:58 AM
92orangeeg
Feb 13, 2005 05:02 PM
