Clutch still slipping!
Old Sep 4, 2006 | 12:04 PM
Wheelman-CZ's Avatar
Default Clutch still slipping!
Hello!
Another friends CRX and another problem! This time it is first generation with ZC1.
There were problem with slippin clutch, so I think it is the clutch disc but when I check it looks good but presure plate was dead. I have changed the pressure plate but it is worst then before.
Can be the clutch disc dead also, I mean the material on it?!? It is thick enought!
Thank you for your help!
Old Sep 4, 2006 | 12:06 PM
Mugencrxsir1's Avatar
Default Re: Clutch still slipping! (Wheelman-CZ)
You need to post a pic for use to help you, then we can make a decision on whether your clutch disc is worn out.
Old Sep 4, 2006 | 01:55 PM
31flavorscivic's Avatar
Default Re: Clutch still slipping! (Mugencrxsir1)
Flywheel may need to be resurfaced
and if you are going to go to that trouble to pull the clutch, just spend the money to get stage 1,2, or stock replacement while you are at it.
The clutch that came with my ZC was beat to ****, so I just did a stage 2 to it.
Old Sep 4, 2006 | 04:46 PM
jdmcars.com's Avatar
Default Re: Clutch still slipping! (31flavorscivic)
Was it all dry when you changed it, no oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 31flavorscivic &raquo;</TD></TR><TR><TD CLASS="quote">Flywheel may need to be resurfaced
The clutch that came with my ZC was beat to ****, so I just did a stage 2 to it.</TD></TR></TABLE>
Agreed . We do also sell clutches if you decide to replace while you have it apart again.
Old Sep 4, 2006 | 04:52 PM
hates hondatech's Avatar
* B A N N E D *
Default Re: Clutch still slipping! (jdmcars.com)
when you refer to ZC1 is that the OBD0 ZC ? did you properly adjust the clutch cable you need to remove the clutch pedal adjusting bolt that will cause the disc to slip.
Old Sep 4, 2006 | 07:47 PM
2slow4stock's Avatar
when you check the disc (which mean you might of pulled the tranny off..) how come you just didn't buy the kit?... Just wonding.. But like someone said maybe oil got behind or infront of the disc or resurface the flywheel.
Old Sep 4, 2006 | 10:56 PM
Default Re
The clutch cable is adjusted right, I have checked it few times.
It is hard to get some clutch in the czech republic further some stage 1 or 2 or something better like that
There were no oil but I havent resurface the flywheel.
crispydee
Oct 20, 2004 11:58 AM
dohcdelsol
14
Aug 16, 2004 10:42 AM
danny98r
Jun 24, 2004 12:15 PM
Nextelbuddy
Mar 5, 2004 06:06 PM
