Cold air intake
Old Sep 4, 2006 | 11:08 AM
thajray's Avatar
Default Cold air intake
I've got a 96 accord lx sedan. I'm adding a cold air intake kit, and have seen pictures with the new round air filtermounted by the battery and then some where the tube goes down to the black box underneath the black box where the stock air filter is. What would be the better mounting or routing for my cold air intake?
Old Sep 4, 2006 | 11:16 AM
gianinline's Avatar
Cold Air intake is the type of intake that goes down to your air box.
Short ram intake ends next to the battery.
Problem solved.
Old Sep 4, 2006 | 11:25 AM
thajray's Avatar
Default Re: (gianinline)
That was simple enough. I figured that was the case. Now, I have to remove my bumper, of which I attempted to do yesterday. No success???? Any hints?
Old Sep 4, 2006 | 11:45 AM
gianinline's Avatar
There have been quite few threads about this issue. You should do a "search".
But anyway, remove your upper grill between headlights. Remove the clips that connect the bumper cover to the reinforcement (should be 3 clips).
There is one clip on each fender, connecting the bumper cover to the fender, you will probably need to turn your wheels when doing this.
Now, under each headlight there's also a few clips. You need to gain access to that, in order to remove the bumper. The headlights themselves are attached to a part of the "radiator support" under the bumper, that means they won't come off before the bumper, so don't try it.
Not sure if the OEM headlight housings could come off leaving the rest of the lamp assembly behind, but I know that aftermarket headlamps for the 5th generation won't do it.
Now, you try it.
Old Sep 4, 2006 | 11:58 AM
thajray's Avatar
thanks. i've identified the clips under the front grill, the ones on the fenders, but the ones under the headlights seem impossible. will do a search in reference to this topic. i do appreciate the feedback's. just found this site today, better late then never.
Old Sep 4, 2006 | 12:02 PM
gianinline's Avatar
Default Re: (thajray)
https://honda-tech.com/zerothread?id=893950
Bright13
Aug 19, 2009 01:38 PM
e_r_i_c_
Nov 11, 2005 05:22 PM
jdmspoonitr
Oct 30, 2003 08:20 AM
OldSchoolHatch
Apr 29, 2003 04:39 PM
ITRacer121
May 7, 2002 03:52 PM
