Spare tire well has water in it....
Old Sep 4, 2006 | 10:19 AM
'90crxSI's Avatar
Default Spare tire well has water in it....
Anyone ever have issues with the drain pipes becoming clogged? (already did a search) I am finding a lot of water in my spare tire well, and cant quite figure out where it is coming from. This seems to be the only place for it to come as the hatch is sealed and there is no trace of water on the inside of the weather stripping. Also, in the hatch area, there are those little vents toward the bottom of the plastic panels near the back of the car, there is water on those vents as well. Like I said, the hatch appears to be sealed. I'm thinking the drainage pipes might be clogged and the water is just running down the sides of the pipes. If anyone has had a similar issue and has fixed it, let me know! Thanks guys...
Old Sep 4, 2006 | 10:41 AM
honda06si's Avatar
Default Re: Spare tire well has water in it.... (88crxSI)
drill a couple holes under the spare tire
Old Sep 4, 2006 | 10:56 AM
EF - R's Avatar
Welcome to the world of EF’s the all leak lol!
I had the same issues; I drilled holes in my winter beater Si. But I fixed the issue with my summer EF. It was coming from the roof under the two plastic sills there was a pin hole causing water the leak down the side of the rear end making a puddle in the spare tire area.
Also had to seal up my rear tail lights, by using another grey foam gasket off a spare set of tail lights I had (doubled up . They can also leak from the gas filler neck.
Honestly the best way to find it is to strip your interior (rear seats too) jump in the car with a flash light and have a buddy soak the car with a hose while you look for the leak.
I used gasket sealer and body sealer, the car never leaked again.
Modified by EF - R at 1:29 PM 9/4/2006
Old Sep 4, 2006 | 10:57 AM
DaNnYsEvEn's Avatar
Default Re: Spare tire well has water in it.... (honda90si)
im not too sure but i remember reading somewhere about water leaking threw the sunroof might make its way down to the hatch area. check out your sunroof
Old Sep 4, 2006 | 11:52 AM
cbp_crx's Avatar
Default Re: Spare tire well has water in it.... (DaNnYsEvEn)
yeah my leak was from the tail light gaskets being bad
Old Sep 4, 2006 | 12:11 PM
'90crxSI's Avatar
Default Re: Spare tire well has water in it.... (cbp_crx)
Thanks for the quick posts guys, it just poored like mad so I'm out to check and see if I can see some leaking.
Old Sep 4, 2006 | 12:26 PM
Jesterian's Avatar
24.243.141.75
I've heard tail light gaskets are the #1 culprit in that area.
Old Sep 4, 2006 | 12:42 PM
'90crxSI's Avatar
Default Re: Spare tire well has water in it.... (Jesterian)
Excellent....it is the tail lights for sure! I popped those lil panels and saw where water was currently streaking due to the massive downpoor we just had. I'll seal them up and let ya'll know if theres anymore!
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaNnYsEvEn &raquo;</TD></TR><TR><TD CLASS="quote">im not too sure but i remember reading somewhere about water leaking threw the sunroof might make its way down to the hatch area. check out your sunroof</TD></TR></TABLE>
x2 they get clocked and cause water to end up in the trunk or floor. Mine is doing this but im too lazy to tear the interior out and fix it
Old Sep 4, 2006 | 01:09 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">I've heard tail light gaskets are the #1 culprit in that area. </TD></TR></TABLE>
Yup! I would get a ******* lake everytime it rained. I changed the tailight gaskets and sealed them with silicon. Never got another leak!
Old Sep 4, 2006 | 01:46 PM
I Like Hondas's Avatar
haha mine is doing the same thing. I'm gonna go out and check my taillights.
Old Sep 4, 2006 | 03:42 PM
Bob_760's Avatar
Default Re: (I Like Hondas)
yep mine used to do the same thing (seemingly through the vents) but it was the tail lights. Got some new gaskets from honda a few weeks ago, put em in, and no more wet trunk for me =D. I might even put some carpet back in now...
Old Sep 4, 2006 | 03:48 PM
EF - R's Avatar
Default Re: Spare tire well has water in it.... (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Yup! I would get a ******* lake everytime it rained. I changed the tailight gaskets and sealed them with silicon. Never got another leak!</TD></TR></TABLE>
I would stay away from silcon it can eat the gasket away, I've used it on my CRX also its a permanent seal. Use body sealer, or gasket sealer. . . . Just my .02
hondatech.101
Honda Fit
Sep 6, 2019 10:34 AM
scyked
Apr 12, 2006 03:45 PM
bbqman
Oct 23, 2005 06:48 PM
JackAcc
Jun 20, 2003 09:10 AM
smacked94gsr
Oct 28, 2002 04:16 AM
