ECU on the ef's
Old Sep 4, 2006 | 08:51 AM
crawlin's Avatar
Default ECU on the ef's
my friend just bought a ef hatch with a b16a where the ecu located i would like to see which one he has also he doesnt have a tach which stock dash that plugs in does
also what motor is a the b16a out of, that is the whole code no numbers also i have an ej so i dont know too much about ef's
Old Sep 4, 2006 | 11:53 AM
mahatma's Avatar
Default Re: ECU on the ef's (crawlin)
ecu is under the passenger footwell carpeting
Old Sep 4, 2006 | 11:57 AM
crxpwr1's Avatar
Default Re: ECU on the ef's (mahatma)
http://faq.ef-honda.com/index....ng=en
Old Sep 4, 2006 | 12:54 PM
crawlin's Avatar
Default Re: ECU on the ef's (crxpwr1)
i looked by the passenger footwell thats the first place i looked i didnt see it there i guess ill look again it was dark the first time i saw it
thanks for the link i found the engine code on there
Old Sep 4, 2006 | 03:42 PM
Ahknodd's Avatar
The ECU is under the passenger side footwell carpeting. Basically where the passenger puts their feet. It's on the slanted part. Just pull back the carpeting, sometimes it's held in there by the plastic clips that hold the plastic panel on the side by the door under the dash. Other than that it should just pull back... the ECU is under a goldish color metal plate that's held down by 4 10mm nuts. Pull that off and there's the ECU.
Hope this helps. later, Davey
Old Sep 4, 2006 | 04:12 PM
crawlin's Avatar
Default Re: ECU on the ef's (Ahknodd)
yeah seen it didnt look hard enough the first time
Old Sep 4, 2006 | 05:00 PM
hates hondatech's Avatar
* B A N N E D *
the ECU for the B16A that came in the EF is a PWO and the PR3 is from a DA6. Need more help call a doctor.
natesfresh
Feb 23, 2008 10:18 PM
darkstarmeyers
Apr 21, 2005 07:47 PM
c_buz
Feb 6, 2005 12:59 PM
95integra_gsr
Dec 18, 2001 03:18 PM
leechungsr
Jul 2, 2001 05:24 PM
