How to remove ECU?
Old Jul 2, 2001 | 01:14 PM
leechungsr's Avatar
Default How to remove ECU?
First of all..where is it? How is it removed?
I'm selling my reprogrammed ECU...
Old Jul 2, 2001 | 02:48 PM
bps2799's Avatar
Default Re: How to remove ECU? (LeeChun GSR)
For a while I was freaked about having the wrong ECU, then I realized that it wasn't under the hood, but under the dash, in the
passenger side footwell, just in front of the door. Pry the bottom fastner out. Unscrew the top one and pull back the trim
from the doorjamb, all gently. Haven't gone farther than this.
Old Jul 2, 2001 | 02:50 PM
TypeC's Avatar
Default Re: How to remove ECU? (bps2799)
It's simple. just rip back the plastic 'door jam', and the ecu is sitting there held on by four bolts at each corner. Take off the bolts, the little ecu shield, and then just unclip the ECU. HTH, -C
Old Jul 2, 2001 | 04:08 PM
LostGsr's Avatar
Leechun why are you selling your ecu? And where did you get it reprogrammed?
Old Jul 2, 2001 | 04:59 PM
leechungsr's Avatar
Default Re: How to remove ECU? (TypeC)
door jam? You mean where the certification label thingie is?
thanks
Old Jul 2, 2001 | 05:24 PM
Tanner's Avatar
New User
Its in the front corner of the passeger side floorboard... it is called a kick panel.. remove it by removing a large plasic screw at the bottom center and a small plastic pop out retainer in the top corner towards the firewall. remove it then the ECU is right behing the plasic kick panel. Not exacly sure how to remove it but unplug the wireing harnesses and probly unbolt the ECU from the car..
Soon 2BE
Oct 28, 2006 01:26 PM
Dubs13
Oct 1, 2006 11:11 AM
vbspec
Apr 8, 2004 03:56 PM
patdemps
Oct 3, 2003 08:57 PM
