What year/model Honda uses the ZC non-vtec motor?
Old Apr 28, 2002 | 02:09 PM
Wet Nudl's Avatar
New User
Default What year/model Honda uses the ZC non-vtec motor?
Will this motor bolt on/drop in to a 89 Civic engine bay without modding the engine mounts? thanks.
Old Apr 28, 2002 | 02:38 PM
JoshM's Avatar
Default Re: What year/model Honda uses the ZC non-vtec motor? (typeRP)
the ZC came in 1988-91 jdm civic si's yes it will bolt right in but you will need to modifly the wiring if you do not have a SI.
Old Apr 28, 2002 | 02:49 PM
Wet Nudl's Avatar
New User
Default Re: What year/model Honda uses the ZC non-vtec motor? (JoshM)
How difficult is it to modify the wiring? Does this motor only work with manual Civic?
Old Apr 28, 2002 | 03:17 PM
EP3_05's Avatar
Which model do you have??? I have seen ZCs swapped in both 5spd and automatic cars so it is possible in both.
Old Apr 29, 2002 | 02:40 AM
Wet Nudl's Avatar
New User
Default Re: What year/model Honda uses the ZC non-vtec motor? (91civic)
EF Civic 4dr (1.5L) automatic. Just looking for a engine replacement when my stock engine goes out.
[Modified by typeRP, 3:40 AM 4/29/2002]
Old Apr 29, 2002 | 07:18 AM
carsaregood's Avatar
the zc wiring for non-si's isn't very tough, there's plenty of really good step by step instructions online all over the place. you should also be able to stick with your automatic transmission if you want to, all you need is an appropriate ecu.
the king.
Nov 25, 2006 12:56 PM
TeamChaotic
22
Feb 1, 2006 10:05 AM
tech6804
Oct 3, 2004 10:37 AM
jester
Jan 23, 2003 05:41 PM
