How can I stop my car from idling higher than normal when the car is cold?
Old Apr 28, 2002 | 02:01 PM
Razor's Avatar
Default How can I stop my car from idling higher than normal when the car is cold?
You know how when you turn on your car (after it has been sitting for like 6-8 hours or overnight) and the car automatically keeps your idle high so your car can warm up faster, well i dont like that and i just want my car to idle at 800 rpms all the time. i heard that the car increases fuel to keep the rpms up. how can i disable this system easily? btw i have an auto if that makes a diff.
thanks
Old Apr 28, 2002 | 02:02 PM
Nick H's Avatar
New User
Default Re: How can I stop my car from idling higher than normal when the car is cold? (Razor)
why would you want to do this...it's in the computer though so good luck trying to tinker with that!
Old Apr 28, 2002 | 02:06 PM
Razor's Avatar
Default Re: How can I stop my car from idling higher than normal when the car is cold? (nickh2k1)
fawk
Old Apr 28, 2002 | 02:17 PM
Milano97's Avatar
You can't do anything about that. I think in my Honda manual it stated that running at a higher idle or rpms or something will warm the car up faster. Just DON'T turn on your car then drive away when it's freezing cold. Give it some time to work up pressure and lubricate the parts thoroughly before taking off.
Old Apr 28, 2002 | 02:52 PM
kurt.'s Avatar
Default Re: How can I stop my car from idling higher than normal when the car is cold? (Milano97)
You can put your car in Drive, the spot marked 'D4' on your gear selector, and hold your foot on the brake until the car warms up. That way your engine will run at a lower rpm.
Only morons runs the stock higher idle when their cars are cold.
You'll definately get more girls with a lower idle too.
Old Apr 28, 2002 | 06:53 PM
Razor's Avatar
Default Re: How can I stop my car from idling higher than normal when the car is cold? (Vantage)
really? you ******* jackass
Old Apr 28, 2002 | 08:27 PM
LookingForVTEC's Avatar
Your car idles higher for a reason when it is cold. If it did not idle at a higher rate when it is cold it would probably stall out. It also runs richer when it is cold because cold engines need more fuel to operate than a warn engines does. My advice would be to leave it alone and leave it up to Honda’s engineers.
Old Apr 28, 2002 | 08:53 PM
Kazmans94cord's Avatar
why dont you like it? its the only way to get your engine warmer faster.
Old Apr 28, 2002 | 10:30 PM
CmptchAV6's Avatar
Default Re: How can I stop my car from idling higher than normal when the car is cold? (aopsunshine)
Not only does the car do this to warm it up quicker but the catalist in the Catilitic Convertor and the O2 sensors dont work at best efficiency when the engine is cold so your car cant really diagnos how the car is running by using the O2 sensor to check for lean or rich conditions so it runs at a higher rpm until it is warmed up and then it is able to use its sensors properly.
Old Apr 29, 2002 | 12:21 AM
IwanAturBo's Avatar
Default Re: How can I stop my car from idling higher than normal when the car is cold? (CmptchAV6)
why mess with something that isnt nessecary?..
jxhxb
Sep 22, 2010 11:17 PM
k20roadrage
Honda Civic (2006 - 2015)
15
Nov 29, 2007 08:24 PM
Prudz_lude
May 16, 2007 09:35 AM
CircuitFG
May 13, 2005 06:05 PM
