Noise from water pump area!!
Old Sep 3, 2006 | 10:25 PM
Ge-money's Avatar
Default Noise from water pump area!!
Motor makes a skreeching sound from water pump/timing belt area. water pump side of timing belt seems to shake. Noise gets louder as i accelerate and seems to come to come and go in cycle when at idle.Had a slight whine before but as of yesterday has turned into a loud screech. Is it bad water pump? does bad water pump make screeching sound? any suggestions would be great. Need to get rid of this noise.
Old Sep 3, 2006 | 10:38 PM
Luserkid's Avatar
Default Re: Noise from water pump area!! (Gmoney16)
Pretty soon you should start noticing radiator/water puddles. Your WP is going out
Old Sep 3, 2006 | 11:25 PM
Ge-money's Avatar
Default Re: Noise from water pump area!! (Luserkid)
aite sounds like i need new water pump. havnt noticed any leaking of coolant but seem to be low everytime i check. thanks for the help
Old Sep 4, 2006 | 01:15 AM
Jimmy's Avatar
Global Moderator
99.9% Sure as posted above it's the waterpump..
Or
If your REALLY lucky.. I've heard spun bearing make some crazy *** noises.
Goodluck bro!
Old Sep 6, 2006 | 08:42 AM
Ge-money's Avatar
aite still making crazy noise! changed watr pump and tensioner, not getting anymore whine or jumpy timing belt but still have screeching/metal griniding noise coming from left of motor.Cant pin point where its coming from. seems to increase with rpm and goes away after idleing for a few seconds. need help!
Old Sep 6, 2006 | 10:51 AM
Ge-money's Avatar
bump.. need this noise gone! anybody?
Old Sep 6, 2006 | 02:55 PM
Jimmy's Avatar
Global Moderator
Default Re: (Gmoney16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gmoney16 &raquo;</TD></TR><TR><TD CLASS="quote">bump.. need this noise gone! anybody?</TD></TR></TABLE>
So you've already replaced the timing belt and waterpump and the noise is still there?
Drain your oil and see if there's metal shavings in the oil.. If so most likely you have a spun rod bearing.. That's all i can think of maybe someone else will chime in
Goodluck
fryman
Aug 22, 2008 10:31 AM
fireant
May 18, 2008 03:35 PM
a_wishbone
May 3, 2007 11:22 AM
riceburners1
13
Jun 2, 2004 10:57 AM
blacksoul
23
Aug 9, 2002 08:22 AM
