Need SRS Flashing Code List. -Please post. "Searched"
Old Sep 3, 2006 | 10:06 PM
dem0nk1d's Avatar
Default Need SRS Flashing Code List. -Please post. "Searched"
I have been searching all damn day trying to find the SRS flash codes. Does anyone have a list of the codes. I mean sheesh why not... I am getting a 2 longs and 1 short. So it should be 21.
Old Sep 3, 2006 | 10:11 PM
2000DX's Avatar
Default Re: Need SRS Flashing Code List. -Please post. "Searched" (dem0nk1d)
SRS Flashing Code? Or do you mean CEL?
https://honda-tech.com/zerothread?id=1171263
Old Sep 3, 2006 | 11:00 PM
dem0nk1d's Avatar
Default Re: Need SRS Flashing Code List. -Please post. "Searched" (2000DX)
I mean SRS. Not check engine codes. SRS codes relay whats going on with your SRS system. "Airbags"
Old Sep 4, 2006 | 12:12 AM
2000DX's Avatar
Sorry bout that, I had a brain fart.
In my HELMS, there is no 21, but there is a 2-1. I'm guessing this is the right one.
It says 2-1: Open or increased resistance in the passenger's airbag inflator.
http://z.about.com/d/autorepai...8.gif
Instead of checking No.1 and No.13, check No.10 and No.14.
I just used that diagram because its basically the same picture in my HELMS but says DTC 2-1 instead of DTC 1-1, and the No.10 and No.14, instead of No.1 and No.13.
Old Sep 4, 2006 | 12:25 AM
dem0nk1d's Avatar
ok thanks, makes alot of sence since my passanger airbag has been taken out. i just installed a integra dash into my eg hatch. so there is no room to hook up the air bag. i've been trying to figure out what kind of resistor i can use in it's place...
some say 2.2k ohms, i've tried that and nothing.... some say 2k ohm (2.0k) so i have to run to the store in the morning...
Old Sep 4, 2006 | 11:45 AM
dem0nk1d's Avatar
tried the 2k ohm resistor on the passanger side still, getting a 2-1.... LAME>
96civic909
Sep 11, 2012 06:06 PM
Jimster480
Aug 29, 2009 11:57 AM
-Todd-
Mar 25, 2006 02:13 PM
Project Dex
Sep 7, 2005 12:26 PM
Toda Built
Jul 10, 2003 02:46 AM
