Rear Disk Brake Conversion Question*****
Old Sep 3, 2006 | 08:46 PM
TyConway21's Avatar
Default Rear Disk Brake Conversion Question*****
i have a 91 hatch si, i am just wondering if the rear brake setup off a 94 up integra will work? i know about the 90-93 integra brakes will work. but anyone know if the 94 up will work also?
Old Sep 4, 2006 | 06:11 AM
Metal Typhoon's Avatar
Default Re: Rear Disk Brake Conversion Question***** (TyConway21)
i quite dont understand ... if you have the si you already have disc brakes. but anyhow in case you dont. I got myself a 90-93 integra rs brakes. Just jump to the junk yeard and get the whole trailing arm with the rotors and caliper. I'm not sure but i believe you will also need the e brake cables. I brought them with me too. I've also heard that the cables might be too long so you can use the crx si's one...
Old Sep 4, 2006 | 07:38 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Rear Disk Brake Conversion Question***** (Metal Typhoon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Metal Typhoon &raquo;</TD></TR><TR><TD CLASS="quote">i quite dont understand ... if you have the si you already have disc brakes. </TD></TR></TABLE>
No, he has a hatch man...they didn't have rear disk, only 90-91 CRX Si's
Old Sep 4, 2006 | 12:02 PM
mahatma's Avatar
Default Re: Rear Disk Brake Conversion Question***** (Deetz)
You can use the '94 brakes but the ebrake cables will likely need to be routed creatively so they're the right length.
(I twisted the two together a few times to take up extra slack)
Old Sep 4, 2006 | 12:12 PM
JapJunkie's Avatar
Default Re: Rear Disk Brake Conversion Question***** (mahatma)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mahatma &raquo;</TD></TR><TR><TD CLASS="quote">You can use the '94 brakes but the ebrake cables will likely need to be routed creatively so they're the right length.
(I twisted the two together a few times to take up extra slack)</TD></TR></TABLE>
I wouldnt twist mine. You should do a lil more research on that year setup before attempting anything.
I would think getting DA E-brakes cables might still work. Last time I checked @ the Honda dealer, 90-91 CRX Si Rear Discs were the same as the 92-95 Civic Si, which can maybe conclud they the same as 94-01 Teg..just a thought. Dont hold me to it.
Old Sep 10, 2006 | 02:41 AM
TyConway21's Avatar
yea i got the swap done the day after i posted this, had no problems with the 96 up disk brakes working, i used the 96 integra ebrake cables also fit perfect and bolted right back in.
whyS0serious
12
Jan 23, 2010 09:51 AM
racingcrx
Nov 22, 2008 03:43 PM
mnichols
Aug 22, 2006 06:59 PM
risiah05
10
Mar 24, 2004 07:11 PM
bbqman
Nov 7, 2003 12:16 PM
