b16 gen 1 injectors
Old Apr 28, 2002 | 01:43 PM
ricodemus's Avatar
Default b16 gen 1 injectors
Yes, I did a search, but didnt see exactly what I wanted. My mechanic said my injectors may need to be replaced, and I was looking for some advice on what I should do for replacement. I'm looking for performance ideas (brands, etc.) and the cost (ballpark). Should I get oem ones (which cars can I source them from)? If I get larger ones, should I get a v-afc? As for the car, its a 90 civic w/gen1 b16 swap with bolt-ons. In the near future (next few months), I'll either be going turbo or maybe continue to build n/a, but either way I'm going past i/h/e. Thanks for your help.
Old Apr 28, 2002 | 03:35 PM
Jared's Avatar
Default Re: b16 gen 1 injectors (ricodemus)
Injectors from a 90-91 Integra will work. And if you go aftermarket and will be specifying size, all you need is a Honda type injector that is low impedence. For a larger injector, I definitely recommend at least a V-AFC. If you're going turbo a larger set would work well, if not, you're probably going to need a lot more than I/H/E in order to take full advantage of a bigger set.
blasterman87
Mar 6, 2010 05:18 PM
sfgreddiedsi
May 23, 2006 10:45 AM
MaaseyRacer
Sep 3, 2003 11:42 AM
spacetuna
Feb 11, 2003 04:46 AM
