Fitting OEM hid's into Ek Civic headlights
i just picked up some g35 hid's and casper shields. ran into a big problem, how do i go about holding the bulbs in place? the oem clips dont fit around the plug that holds the bulb.
i know a ton of you have done this before so what did you do?
rebend the clips so they fit, If that doesnt work your going to have to get a metal wire and bend those and replace the oem ones. My friend used rubber bands; but its only a temporary solution.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Samurai »</TD></TR><TR><TD CLASS="quote">rebend the clips so they fit, If that doesnt work your going to have to get a metal wire and bend those and replace the oem ones. My friend used rubber bands; but its only a temporary solution. </TD></TR></TABLE>
i dont think i can rebend the orginal clips beacuse they are too small. i guess ill try to get some metal wire and try that.
anyone else?
anyone else?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flava »</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NrG »</TD></TR><TR><TD CLASS="quote">make a new clip using a paper clip.
I didn't think you could use D2R bulbs with casper shield. I always thought they were for hid kits with a rebased bulb.</TD></TR></TABLE>
whats a rebased bulb? it fits fine inside with everything, just the clips doesnt fit and the rubber seal doesnt fit either.
but ill try this weekend.
Flava
10
Sep 7, 2006 06:55 PM
deviant1
Apr 4, 2004 03:22 PM
