which wastegate spring so i have? (pics)
Old Sep 3, 2006 | 07:44 PM
integra3586's Avatar
Default which wastegate spring so i have? (pics)
both of these were in my 44mm TIAL wastegate
which one is which? i know they are color coded
my setup has not been installed yet. need to know which these are, i want to go probably with a 7-10 psi spring
Old Sep 3, 2006 | 07:45 PM
EK k kay's Avatar
Default Re: which wastegate spring so i have? (integra3586)
https://honda-tech.com/zerothread?id=857805
Old Sep 3, 2006 | 07:48 PM
Default Re: which wastegate spring so i have? (EK k kay)
thanks man, for some reason i did not see that when i searched
Old Sep 3, 2006 | 07:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Wastegate - 35mm
<u>BAR</u> // <u>PSI</u> // <U>Color</U> // <u>OD</u>
0.30bar // 4.35psi // Sm. <FONT COLOR="yellow">Yellow</FONT> // 1.875in
0.45bar // 6.53psi // Sm. <FONT COLOR="red">Red</FONT>
0.65bar // 9.43psi // Sm. <FONT COLOR="green">Green</FONT>
0.8bar // 11.60psi // Sm. <FONT COLOR="blue">Blue</FONT>
Wastegate - 35mmHP
0.95bar // 13.78psi // Big<FONT COLOR="yellow">Yellow</FONT> // 1.875in
1.10bar // 15.95psi // Big<FONT COLOR="red">Red</FONT>
1.35bar // 19.58psi // Big<FONT COLOR="green">Green</FONT>
1.5bar // 21.75psi // Big<FONT COLOR="blue">Blue</FONT>
Wastegate - 38/40mm
0.25bar // 3.63psi // Sm. <FONT COLOR="yellow">Yellow</FONT> // 1.875in
0.4bar // 5.80psi // Sm. <FONT COLOR="red">Red</FONT>
0.5bar // 7.25psi // Sm. <FONT COLOR="green">Green</FONT>
0.6bar // 8.70psi // Sm. <FONT COLOR="blue">Blue</FONT>
0.7bar // 10.15psi // Big <FONT COLOR="yellow">Yellow</FONT> 2.36in
0.8bar // 11.60psi // Big <FONT COLOR="red">Red</FONT>
0.9bar // 13.05psi // Big <FONT COLOR="green">Green</FONT>
1.0bar // 14.50psi // Big <FONT COLOR="blue">Blue</FONT>
1.1bar // 15.95psi // **
1.2bar // 17.40psi // **
1.3bar // 18.95psi // **
1.4bar // 20.30psi // **
1.5bar // 21.75psi // **
1.6bar // 23.20psi // **
Wastegate - 44/46mm
0.2bar // 2.90psi // Sm. <FONT COLOR="yellow">Yellow</FONT> // 1.875in
0.3bar // 4.35psi // Sm. <FONT COLOR="red">Red</FONT>
0.4bar // 5.80psi // Sm. <FONT COLOR="green">Green</FONT>
0.5bar // 7.25psi // Sm. <FONT COLOR="blue">Blue</FONT>
0.6bar // 8.70psi // Big <FONT COLOR="yellow">Yellow</FONT> // 2.36in
0.7bar // 10.15psi // Big <FONT COLOR="red">Red</FONT>
0.8bar // 11.60psi // Big <FONT COLOR="green">Green</FONT>
0.9bar // 13.05psi // Big <FONT COLOR="blue">Blue</FONT>
1.0bar // 14.50psi // **
*All Standard WG35mm Springs can also be used for WG35mmHP
**You can combine Big&Small Springs to get the PSI that you need for HP
Modified by Hoosier Daddy at 3:42 PM 5/7/2004</TD></TR></TABLE>
so i can just use the smaller one right? all i need is about 9psi
edit: thats only 3 psi
Old Sep 3, 2006 | 07:51 PM
EK k kay's Avatar
Yes, but it would be better to keep the spring size as close to your required psi as possible. Maybe you can sell those two and get the spring you want. Brand new they are about $30 each.
Old Sep 3, 2006 | 07:54 PM
yea i just realized the small yellow is only 2.9 psi, and the big green is 11.6. looks like i will have to go with some different sizes
tallblondkid
Jun 3, 2006 04:11 PM
HickamHatch
Oct 26, 2005 06:57 PM
civic_6991
Feb 23, 2004 10:35 AM
Hoodwinked
Oct 26, 2003 08:29 PM
