B16 head on b18a block
I am new to this site but not new to cars. I have a 94 civic with a complete b18a swap and am thinking about putting a b16 head on it. It comes complete with intake,exhaust manifold, distributor, and tb. What i need to know is how hard is the swap, what else will i need besides a new timing belt, water pump, and chipped ecu. I also have already on the car, type R tranny, b16 pistons, stage 2 crower cams, header, intake, and SAFC.
He is right! The reason i dont have a lot of post is because i search and i find everything i need so do the same. So like you said before... If you dont search before you post, dont post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR »</TD></TR><TR><TD CLASS="quote">Do a search for lsvtec or ls/vtec.There are hundreds of threads on this setup.</TD></TR></TABLE>
this guy is right, the search engine is VERY helpful.... with that said,
I have been looking to do the same set-up. I have a b18b and will be setting it up for ls/vtec. So I have been recently searching for stuff, because I have seen WAY too many peeps getting FLAMED. Here is the list that I have started to compile, hopefully it will help you out . So, here you go man, (next time just search first):
http://www.sportcompactcarweb....ngine/
http://www.c-speedracing.com/h...c.php
http://www.inlinefour.com/
https://honda-tech.com/zerothread/650230
http://hondaswap.com/hybrid-ed...26851/
http://www.c-speedracing.com/h...p.php
http://honda.hybrids.jp/b20tech/index.shtml
https://honda-tech.com/zerothread?id=1676914
https://honda-tech.com/zerothread?id=1499806
yea its just an lsvtec convo that yourdoing... you need a oil line ran from the block to the head you can t fit it or use the adapter for the oil filter... youd also need to tap and re dowell the head... not too hard
em2ssm02
Jun 22, 2006 12:18 PM
t616
Jul 23, 2002 10:46 AM
