es motor mount inserts
Old Sep 3, 2006 | 06:28 PM
sohctodohc's Avatar
Default es motor mount inserts
ok so i went to put these into my motor mounts today and ran into a couple of problems.
the first being that they didnt fit whatsoeverrrrrrr. they are suppose to go into the side right and be nice and easy goin in?
welp mine didnt fit what so ever so i started to file and cut and lube and pinch and squeeze and nothing. at the end of the day i figured it out.
i think summit racing sent me the wrong ones so i need the part number of the es motor mount inserts for a 94 civic ex with the z6 in it thanks.
and if i could get some pics or something of an installed motor mount insert on a motor mount that would help to. thanks
Old Sep 3, 2006 | 06:51 PM
Heretic:Si's Avatar
Default Re: es motor mount inserts (sohctodohc)
if you remove the mount the inserts should slide right in no problem. sounds like you got the wrong ones.
Old Sep 3, 2006 | 09:44 PM
sedativ_02's Avatar
Default Re: es motor mount inserts (Heretic:Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">if you remove the mount the inserts should slide right in no problem. sounds like you got the wrong ones.</TD></TR></TABLE>
you think?? lol he already stated that. he's needing the PART NUMBER. idk it man but free bump for you for some help from anybody who actually knows what theyre talking about.
Old Sep 3, 2006 | 09:47 PM
WhiteOnRice's Avatar
Default Re: es motor mount inserts (fuck_you)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuck_you &raquo;</TD></TR><TR><TD CLASS="quote">you think?? lol he already stated that. he's needing the PART NUMBER. idk it man but free bump for you for some help from anybody who actually knows what theyre talking about.</TD></TR></TABLE>
Heretic:Si answered his question (they are suppose to go into the side right and be nice and easy goin in?) so chill out, ***.
Good luck returning the inserts after taking a file to them...
Old Sep 3, 2006 | 09:57 PM
byronl's Avatar
I believe the part number is 16.1105R, I just installed the es motor mounts for my 93 civic coupe today. Goooood shiiiiiit since my mounts were basically ripped already hahah.
Old Sep 4, 2006 | 12:28 AM
sohctodohc's Avatar
Default Re: es motor mount inserts (byronl)
thanks everyone i will have to check the part number on the box i have to c if it matches up which i already know it wont but hey. i didnt plan on returning them. they are from sumit and there customer service sucks. ill just pitch them i guess
Old Sep 4, 2006 | 08:23 AM
Sell them on ebay...
Old Sep 4, 2006 | 08:45 AM
crawlin's Avatar
Default Re: (fizix_skate)
i just installed my inserts on my car 94 ej with a b18 i think the b series mounts are different not sure but the driver side motor mount is a bitch you have to cut out the inside then hammer out a metal lining then slide in the insert the back and pass side motor mount were cake but the car definatly rattles a **** load now but feels a lot stiffer worth it if you dont care to much about comfort or the bitchy passengers
Old Sep 4, 2006 | 12:07 PM
super_nguyen's Avatar
Default Re: (crawlin)
where is the back one located? i looked underneath the car and i couldn't see it, but then i wasn't sure what the shape of it was. i could only get the inner side of the driver's side mount, the outer side was ******* impossible.
Old Sep 4, 2006 | 12:30 PM
Heretic:Si's Avatar
Default Re: (super_nguyen)
the rear mount is under the intake manifold. i didn't have to cut or hammer anything on my driverside mount, just lowered the motor a little took off the stock mount, put the insert in and put everything back together. vibration is very minor at idle. this is on a em1
Old Sep 4, 2006 | 01:34 PM
crawlin's Avatar
Default Re: (Heretic:Si)
i have a built b18 in a ej so the mounts could differ and rattling would be less severe in a stock car from your em1 trust me the type of inserts i had you couldnt get the driver side in any other way.
but for super_nguyen the back mount is there but it could be kind of hard to see i just took out the bolts and moved the mount up and forced them in easiest way
Old Sep 4, 2006 | 01:37 PM
Heretic:Si's Avatar
all b-series torque mounts are alike. at least all the ones i've seen. what kind of inserts did you have?
Old Sep 4, 2006 | 01:57 PM
crawlin's Avatar
i have prothane motor mounts thats what it says on the box
Old Sep 4, 2006 | 02:53 PM
sohctodohc's Avatar
ok so the part number does match up......ok can i get a diagram of the mounts or pictures or something to make sure im doin this right?
Old Sep 4, 2006 | 04:19 PM
byronl's Avatar
didn't u get an instruction sheet that came with the mounts?
Old Sep 4, 2006 | 05:39 PM
sohctodohc's Avatar
nope. could someone send me a pic of the instruction sheet
Old Sep 4, 2006 | 06:50 PM
byronl's Avatar
here you go
Old Sep 4, 2006 | 07:00 PM
meagainsttheworld's Avatar
okay im just making sure... but are u trying to put the inserts in the right mounts?
because i got those inserts and they went right in and i have a 94 civic dx coupe...
are u trying to put them in the torque mounts which are
tranny side lower mount, drivers side lower mount and the back one... im hoping ur not trying to put them into the upper mounts
Old Sep 4, 2006 | 08:36 PM
sohctodohc's Avatar
Default Re: (meagainsttheworld)
hmmm we puuled the mount that was on top of the transmission next to the shock tower thing
Old Sep 4, 2006 | 08:50 PM
byronl's Avatar
Default Re: (sohctodohc)
yea, that's the wrong mount, it's the torque mounts u have to remove. You'll see it when you go under the car.
Old Sep 5, 2006 | 02:11 AM
problem solved
Old Sep 5, 2006 | 12:03 PM
sohctodohc's Avatar
yay thanks everyone. one more thing do you think with the mount i cut up a lil bit will it work or not?
Old Sep 6, 2006 | 01:38 PM
sohctodohc's Avatar
so i got 2 of the inserts in and the one behind the engine is the only one left. some tips or advice on making this one easier would b great
Old Sep 6, 2006 | 02:21 PM
jdmeg9's Avatar
also heres a little FYI. the ES inserts will not fit non oem mounts. i had a broken torque mount on my civic that i found when taken the insert and mount out when putting a hasport rear drag mount in and bought one from O'reilys and they wouldn't fit at all so i took it back bought a mount from honda and fit fine.
Old Sep 6, 2006 | 06:34 PM
sohctodohc's Avatar
Default Re: (jdmeg9)
ok so i tried to put the rear mount in tonight and it was horrible. i couldnt get round to anything. so does neone have some tips for thismount. also would t be easier o d when the transmission is out bc im pullin the tranny here soon so should i just wait till i do that or did i make thisharder than what it is
