SOHC Owners, NRG Engine Dampner fits!!
Old Sep 3, 2006 | 03:57 PM
Knightmare69's Avatar
Default SOHC Owners, NRG Engine Dampner fits!! *Big Pics Added*
Ok I can't believe I didn't realize this before, After sitting on the kit for almost 2 months and having Roth from NRG trying to find ways to fit it since it's actually made for a DOHC accord, I got it to fit. I will try to take pics tomorrow but for now I will just tell you how I finally got it to fit.
One end is bolted to the control Arm bolt, the other is to the top bolt of the power steering. You will need to go to autozone and get a longer 10mm bolt, I think it's called M6-1 or something, worse case scenerio is just bring a 10mm socket and unbolt it at autozone and find the same one that they offer but just longer.
I can't say for sure if this is actually an improvement but I notice that you def. feel the engine vibrations a lil more since it's purpose is to prevent the engine from torque too much under load. I will be keeping an eye on the kit tomorrow and next weekend to make sure that the kit is still well in place. Just figured I'd let you all know that the kit is fitable. BTW, I installed it on my gf's 96 Ex.
Modified by Knightmare69 at 9:10 PM 9/4/2006
Old Sep 3, 2006 | 05:34 PM
Slomies's Avatar
post a pick FTW
Old Sep 3, 2006 | 10:36 PM
importfanatic17's Avatar
Default Re: (Slomies)
Yeah, a pic would be sweet. You mounted it to where it still functions like it is supposed to?
Old Sep 4, 2006 | 01:31 PM
I need a place to host the pics.
Well, from driving it so far, I can tell you that at idle, you can def. feel a difference in vibrations, you will feel more then usual but then I suppose that's how you know the brace is working since it's suppose to limit the movement of the engine.
We took it for a spirited drive between LI and NYC and I can def. say that the power is getting to the wheels alot better, and since my gf drives an auto, she needs all the help she can get. I thought that this was a fair compromise for ppl that don't need or want to swap their mounts for poly versions but still wanted the ability to better get their power to the ground.
Old Sep 4, 2006 | 04:58 PM
[IMG][/IMG]
Old Sep 4, 2006 | 05:04 PM
[IMG][/IMG]
Old Sep 4, 2006 | 05:06 PM
Default Re: (Knightmare69)
[IMG][/IMG]
Old Sep 4, 2006 | 05:09 PM
[IMG][/IMG]
Old Sep 4, 2006 | 06:50 PM
SuShiBoiiii's Avatar
looks good so pretty much all you had to get was a longer screw?
Old Sep 4, 2006 | 06:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuShiBoiiii &raquo;</TD></TR><TR><TD CLASS="quote">looks good so pretty much all you had to get was a longer screw? </TD></TR></TABLE>
Yup, so far it's holding in there well and I've been checking every chance I get. I tried Home Depot first but the threads on the screwd there are too corse. I then went to autozone and they had the perfect bolt, it was M6-1 I think, 10mm just like OEM and longer. I was worried at first because if you look at the bracket and the OEM piece that the bolt goes into, it seems like you need an even longer one but me and my gf took it for a test run last night and at times were doing well over 100 for some sprints (not that I condone these actions but it was like 2am) but mostly crusing between 60-85mph and afterwards I checked the kit and everything was still well bolted in place. I have the washer because in a moment of frustration and confusion before I thought about a longer bolt, I thought about trying to use the OEM bolt and thought if I kinda grinded down the bracket I'd have enough play to use the OEM bolt. In the end I slapped myself and just went and got a longer bolt.
Old Sep 4, 2006 | 08:11 PM
hb_guy's Avatar
Default Re: SOHC Owners, NRG Engine Dampner fits!! *Big Pics Added* (Knightmare69)
subscribed!!
how does it feel in between shifts?? does it bog less?? details....
manhattan huh.... i am from jersey city...
Old Sep 4, 2006 | 08:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hb_guy &raquo;</TD></TR><TR><TD CLASS="quote">subscribed!!
manhattan huh.... i am from jersey city... </TD></TR></TABLE>
Well, she drives an auto so regardless it'll bog some what but this helps reduce the bogging. We noticed this especially on the highway when accelerating. As for driving around town, there is just less of a bog.
Old Sep 4, 2006 | 10:07 PM
iLUVmyACCORD's Avatar
so can someone put what this device actually does or what its supposed to do in dummy terms?
thanks
Old Sep 5, 2006 | 02:15 AM
Default Re: (iLUVmyACCORD)
It is supposed to keep your engine still. Every time you take off, your engine kinda lurches and screws you over, this is supposed to reduce that.
Old Sep 5, 2006 | 12:28 PM
scabbs's Avatar
Default Re: (importfanatic17)
I'll prolly purchase one of these soon. thas awesome. I give you props for bein a badass.
Old Sep 6, 2006 | 12:06 PM
hb_guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Knightmare69 &raquo;</TD></TR><TR><TD CLASS="quote">
Well, she drives an auto so regardless it'll bog some what but this helps reduce the bogging. We noticed this especially on the highway when accelerating. As for driving around town, there is just less of a bog. </TD></TR></TABLE>
RACEPAK
Honda Civic (2006 - 2015)
Feb 14, 2016 03:02 PM
thrty8street
Aug 28, 2015 04:29 PM
k-series
Sep 19, 2005 03:53 AM
Arch-Angel
May 15, 2003 11:08 PM
