is this a GSR or SI sway bar? help please!
i just bought a sway bar and the guy said it was a gsr but when i got home to fit it, it wouldnt fit. can someone tell me what it is? thanks in advance! btw i have a 92 civic with gsr LCA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 »</TD></TR><TR><TD CLASS="quote">
why dont you measure it? its supposed to be 13mm thick. But I really think it should go the other way... mine was a pain in the *** too, but finally got it mounted (mine is the ITR bar with si endlinks).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxhatch92 »</TD></TR><TR><TD CLASS="quote">my dad just measured it with some device with a dial on it. it was 13mm. i thought gsr was supposed to be 14mm?</TD></TR></TABLE>
then you have the si bar which will only work with the si endlinks. maybe contact the seller?
i dont know which sway bar it is but you are missing some brackets.
http://www.acuraparts247.com/p...ch=no
number 12/13
number 12/13
GSR and Si both had 13mm bars.. they are different though. the Integra one i think is longer. the 14mm bar came off 4 door GSRs. and just like the above said, you are missing some brackets..
the post a couple post ahead of me with the ITR bar is actually incorrect and will have binding because the endlinks arent at the right angle.
get the brackets and turn your sway bar over, the pics with it on the car, you have it upside down.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ej0513 »</TD></TR><TR><TD CLASS="quote">. the 14mm bar came off 4 door GSRs. </TD></TR></TABLE>
my friend had a 14mm on his 2door... is that for certain years?
this is a civic rear swaybar. there is an extra curve in the bushings area which only civics have. hence why it doesnt fit correctly due to the extra curve in the bar.
also the bar is upside down. you want the curve to be on the top not on the bottom. just like in this photo.
GET YOUR MONEY BACK! AND GET A 23MM REAR JDM ITR REAR SWAY INSTEAD!
looks like your missing the brackets that bolt to the subframe, then the D-brakcets you have there will bolt to the ones your missing.
my gsr bar also has green paint, don't know if that means anything
gl
gl
i dont think that bar is from a 99-00 si. it has integra endlinks. if its a gsr bar, it will fit, thats whats on my hatch, but you do need the brackets that go between the bar and the subframe. also in the one pic where you have the bolt in the lca it is in the wrong side. it goes through the endlink and the into the lca. this is the only pic of mine but you can kinda see the subframe brackets.
click to enlarge.
click to enlarge.
^i feel the same.. i think it is an Integra bar considering it has the endlinks from an Integra.. get the brackets and hardware (dont forget to get the bolts and flanged nuts for the inside of the subframe) first then go from there.. one step at a time.
^someone already linked you to it.. you can but it there and it might be cheapest youll find. i know in the SF Bay Area that website that was posted is by far cheaper than dealers around here.
TurboBumblBee
May 12, 2003 08:39 PM
