gsr front sway bar on 94 Si hatch.. whats needed?
i plan on upgrading the stock civic si front sway bar to a gsr bar cause i got it cheap.. will it bolt up using the stock civic endlinks and parts i already have or will i have to go out and buy parts to fit the gsr sway bar onto a car that already has a sway bar..
Re: gsr front sway bar on 94 Si hatch.. whats needed? (Hybrid95CivicEX)
You will need different endlinks and different bushings
because the bar you are using is bigger and the bushings
will be too small. The endlinks you are looking for are kinda
like a 2 piece. Shaped like a L. It pivots on the part of the
middle part of the L.
Re: gsr front sway bar on 94 Si hatch.. whats needed? (d15dude)
exactly what the guy above me said.
i'd get polyurethane bushings, and gsr d brackets plus the gsr endlinks, and you should be ready to go. it's a cake install
i did the same bar on my 95 si... you also need the gsr endlinks and bushings that go between the bar and crossmember...as for mounts for the bushings i dunno. i used the gsr's cause i had em'. they <U>look</U> the same though.
bboygreddy
12-05-2006 09:25 AM
