CODE 14 (EACV) Doesn't go away..How do you reset the ECU?
I probably need the main wiring harness because there is an open or a short somewhere from my EACV to Fuse 14. Well at least thats what the book says.
Modified by 88DXREX at 12:43 AM 9/4/2006
Remove the hazard fuse in the under-hood fuse box for 15 sec. If you have tested the IACV and found the wiring faulty then the code will reappear once the ecu detects a problem.
CRX Hooptie
17
Feb 19, 2011 12:14 AM
