Best way to get rid of WHEEL HOP
Old Apr 28, 2002 | 12:16 PM
All Motor EG's Avatar
Default Best way to get rid of WHEEL HOP
WHAT DO YA THINK THE BEST WAY TO GET RID OF WHEEL HOP IS. OR THE EASIEST WAY
Old Apr 28, 2002 | 12:35 PM
beeboyee's Avatar
Default Re: Best way to get rid of WHEEL HOP (All Motor EG)
suspension and better tires!
Old Apr 28, 2002 | 12:49 PM
Black_eh2's Avatar
New User
Default Re: Best way to get rid of WHEEL HOP (beeboyee)
get some prothene motor mounts and some better tires.
Old Apr 28, 2002 | 12:54 PM
93delsol's Avatar
New User
Default Re: Best way to get rid of WHEEL HOP (SleeperEG6)
z10 radius rods
Old Apr 28, 2002 | 12:57 PM
Default Re: Best way to get rid of WHEEL HOP (93delsol)
have tires and place racing mounts... maybe new struts and stuff.
Old Apr 28, 2002 | 01:52 PM
hatchmobile's Avatar
z10 radius rods
greatest thing since i put in my lsd...wheel hop is gone
Old Apr 28, 2002 | 02:01 PM
Phantom's Avatar
slicks?
Old Apr 28, 2002 | 02:10 PM
june's Avatar
Old Apr 28, 2002 | 02:28 PM
dom93hatch's Avatar
Default Re: Best way to get rid of WHEEL HOP (civicefhatchback)
Traction bars
Old Apr 28, 2002 | 02:50 PM
JDMvtecDRAGSTA's Avatar
Default Re: Best way to get rid of WHEEL HOP (dom93hatch)
thousand pound springs and energy suspension motor mount inserts are a good start.
Old Apr 28, 2002 | 09:02 PM
Naya the Dingo's Avatar
Default Re: Best way to get rid of WHEEL HOP (sohcmydohc)
He said he has Place Racing motor mounts, which are much better than ES polyurethane inserts. I've heard of the traction bars but don't know how well they work. I have also seen in rare instances the PR mounts break, check them to make sure they are not broken.
Old Apr 28, 2002 | 10:18 PM
Hybridhonda561's Avatar
the "competition engineering" tractions bars are easier to use and install..you have more options and its all together a better setup...you can find them online or at your local shop or even look in the summit racing catalog..
Old Apr 28, 2002 | 11:28 PM
Maximus's Avatar
Default Re: Best way to get rid of WHEEL HOP (Hybridhonda561)
With the z10 radius arm bars does it effect any part of the suspension. I would like to both drag race and track race my civic. Would the z10 bars hinder me on the track in some way?
Old Apr 29, 2002 | 12:31 AM
Blkhatchbk's Avatar
little less air in the tires?
Old Apr 29, 2002 | 12:38 AM
NorthernXposure's Avatar
Default Re: Best way to get rid of WHEEL HOP (Blkhatchbk)
urethane motor mounts, my brother use to get mad wheel hop in his type r... put urethane motor mounts and hasnt had any complaints.. except for a lil more motor vibration throughout the car
Old Apr 29, 2002 | 05:40 AM
jg's Avatar
jg
Default Re: Best way to get rid of WHEEL HOP (Maximus)
With the Z-10 kit, you can turn the wheels without any problems. That CANNOT be said for the Comp. Engineering set-up. Their front pivot points are too far outward and hit the tires/wheel if you turn them too far(this is why they sell steering stops as a supplement).
I hae the Z-10 kit , and a full set of ES motor mount inserts, with a built b20vtec and have NO wheel hop. I also run 205/40 17" BFG drag radials in the front.
Old May 6, 2002 | 06:18 PM
-Gambit-'s Avatar
Default Re: Best way to get rid of WHEEL HOP (C5_ALLMOTOR)
z10 radius arms. here is a link to the install on my car (weak burn out i know hehee) http://www.overboost.com/story.asp?id=460
Old May 7, 2002 | 01:30 AM
sparkz's Avatar
Default Re: Best way to get rid of WHEEL HOP (gambit33)
also, replacing old worn rubber joints in the upper and lower arms help too.
Old May 7, 2002 | 01:52 AM
hybrider's Avatar
z10 radius rods
and a lsd, and your set
Old May 18, 2002 | 04:01 AM
Muckman's Avatar
Moderator in Chief
I cant believe overboost.com actually charges money to download the videos from their site.
Old May 18, 2002 | 05:49 AM
Pat McGroin's Avatar
Default Re: Best way to get rid of WHEEL HOP (Muckman)
you need to obey the D
Old May 18, 2002 | 06:36 AM
Mista Bone's Avatar
D Tranny Guru
learning to drive and set air pressure is all that is needed.
RSX_S
10
Jun 2, 2008 11:09 AM
teddy_dc2
May 2, 2006 10:32 PM
zexifiedlude
Apr 4, 2005 05:22 PM
kani
12
Sep 23, 2004 11:41 AM
pentaq
Apr 1, 2003 08:46 AM
