will bad gas make your motor nock?
Old Sep 3, 2006 | 11:13 AM
cviccoupe's Avatar
Default will bad gas make your motor nock?
it sounds like i have a rod nock but the engine has 20-30k ....but yea it starts at around 3,000 rmp and sounds kinda like a rod knock,i pulled each spark plug wire otu one at a time and still the same thing a went under the car and started it and it does make that noise around there..it really weird like i said ...in the hayens manual its says that it could be from not the right octane or old gas....when i boughtthe car it had a 3/4 a tank full but has been sittin for over a year because of a bad tranny.so i bought it and put a tranny in it and i never heard the sound then i let it sit for a month while i did body work on it and changed the oil with the cheapest oil in it from advance auto then i noticed the noise...
Old Sep 3, 2006 | 11:17 AM
spoonracer84eg's Avatar
Default Re: will bad gas make your motor nock? (cviccoupe)
Yes but if you have a knock sensor it should keep the motor from knocking by running rich. What motor do you have because not all motors have a knock sensor?
Old Sep 3, 2006 | 12:29 PM
cviccoupe's Avatar
Default Re: will bad gas make your motor nock? (spoonracer84eg)
a sohc vtec 94
Old Sep 3, 2006 | 12:43 PM
What ecu are you running??
Old Sep 3, 2006 | 09:25 PM
mugenpowered's Avatar
If gas sits for over a year it loses octane, and low octane can cause knocking so it could be that. But considering that you didn't hear it at first I am not so sure.
I have never tried octane booster, but I guess it is used in situations like this and might help, but I don't know, don't take my word for it.
Honda3133
37
Sep 1, 2011 02:08 AM
preludedriva
Jan 24, 2010 01:29 PM
pumpkyn
10
Sep 30, 2006 03:20 PM
a1320honda
Jun 17, 2004 03:58 PM
Sqweak
May 11, 2003 01:06 PM
