car amp / sub only works when the car is on ACC :(
Old Sep 3, 2006 | 06:36 AM
ekcivic9's Avatar
Default car amp / sub only works when the car is on ACC :(
heyya HT,
i havent driven my car for about a week or so, and i think my sound system decided to crap itself out
when i turn the car on, the amp starts to blink and theres no bass... however, the headunit and the speakers still work.
but if i leave the car in ACC, but dont fully start it, my subs hit just like they did two weeks ago.
does anybody know what is wrong??!
any help would be appreciated
Old Sep 3, 2006 | 08:02 AM
fcm's Avatar
fcm
Old Fart
Default Re: car amp / sub only works when the car is on ACC :( (ekcivic9)
Check all the power and ground connections, including the batt. terminals. 94
Old Sep 3, 2006 | 09:55 AM
02 accord's Avatar
What happens when you turn on the ignition (one click past acc), but don't start the car? Does it do the same thing?
Old Sep 3, 2006 | 10:00 AM
ekcivic9's Avatar
i still get audio :S im so confuse right now.
i think im just going to disconnect all the connections and reconnect them just to be sure.
Old Sep 3, 2006 | 03:07 PM
fcm's Avatar
fcm
Old Fart
Default Re: (ekcivic9)
The amp needs way more current then the HU does, so check those connections, also make sure the fuse in the amps power line is making a good connection, and if its an AGU fuse... http://www.scosche.com/efx.asp...50F4I like one of those, replace it even if it looks good. 94
Old Sep 3, 2006 | 03:52 PM
02 accord's Avatar
Default Re: (fcm)
Check the voltage that you're getting when the car is running. Maybe your alt regulator went bad and is putting out more than 14v, and the amp is shutting itself down due to overvoltage.
Old Sep 3, 2006 | 04:15 PM
ekcivic9's Avatar
i picked up new fuses from a local shop today and reconnected the grounds. and everything is dandy again
yay!
thanks guys
Old Sep 3, 2006 | 06:36 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
I hate agu fuses now and reccommend stepping up to anl. way better quality and don't have probs with fake blow out fuses
LSej1
Audio / Security / Video
13
Oct 6, 2011 05:32 AM
ef_88_hatch
13
Sep 13, 2008 12:53 PM
ITB
Nov 12, 2005 11:10 AM
skrewdriver88
12
Jul 12, 2004 01:15 AM
shamoo
Oct 18, 2002 05:38 PM
