Squeling after brake and bearing job 96Ex
Old Sep 2, 2006 | 10:44 PM
Knightmare69's Avatar
Default Squeling after brake and bearing job 96Ex
I got new slotted rotors all around and new pads as well as the front bearings changed. Now I have a sort of squeeking squeeling noise and I don't know if it's the bearing or the brakes breaking in. It sounds like it's coming from the driver side.
I got Centric Hp slotted rotors and PBR semi metallic pads installed, is there a way to determine what the noise is being caused from before I send it to a shop to have it dismantled? TIA
Old Sep 11, 2006 | 09:07 AM
Default Re: Squeling after brake and bearing job 96Ex (Knightmare69)
Ok so the went into the shop and some of the noise was caused by a bad balljoint. However the squeling still exists and i can't determine if it is the bearings we just replaced or if it is the new slotted rotors and pbr pad we installed. He squeling happens while the car is in motion and usually stops when the car is stopping or at least quiets down. Help.
bestofthe80s
Jul 9, 2017 01:29 PM
Rick1t
Mar 13, 2012 11:42 AM
KraZyCHOWMEIN
Feb 19, 2010 04:37 PM
crxsleeper210
11
Jul 21, 2008 07:41 PM
GSRNetics
Jul 9, 2006 08:33 PM
