I need a tool that will help me figure out bend angles.
Old Sep 2, 2006 | 06:44 PM
danielm3's Avatar
Default I need a tool that will help me figure out bend angles.
I have a header I want to make a copy of (my own design and creation not looking to copy anyone), so I am looking for a tool I can place on the pipe that will tell me what the angles of the bends are.
For example if one primary pipe has 4 bends in it, a tool that will tell me exactly what the angles on those bends are.
Hope this make sense.
Old Sep 2, 2006 | 06:56 PM
GTiR NX's Avatar
Default Re: I need a tool that will help me figure out bend angles. (danielm3)
Tig wire ( any stiff wire ) and a protractor
Just line it up down the center line of the pipe and lay it on the protractor.
Old Sep 2, 2006 | 07:31 PM
KFMRC's Avatar
There are several manufacturers that make measuring tools like a faro arm for reverse engineering tubular assemblies. They are at least 35K.
The least expensive way is take a 90 degree bend and measure around the outside. Take the length around the outside and divide it by 90 and you will have the value of each degree.
Example
distance around the perimieter of a 90 degree bend = 6.125 " / 90 = .068" per 1 degree.
now measure a bend 4.313" / .068= 63.4 degrees
you will need to convert measurements to decimals
1/64 = .015625
1/32 = .03125
1/16 = .0625
Old Sep 2, 2006 | 08:24 PM
CRMB's Avatar
OG Fabricator
You can pickup an angle finder from most hardware stores - they are yellow/orange and have a swinging arm that you line up with the centerlines of the bend. You can get +/- 5 degrees or better with one of these.
Old Sep 3, 2006 | 01:06 AM
danielm3's Avatar
Default Re: I need a tool that will help me figure out bend angles. (Racing-Solutions)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racing-Solutions &raquo;</TD></TR><TR><TD CLASS="quote">You can pickup an angle finder from most hardware stores - they are yellow/orange and have a swinging arm that you line up with the centerlines of the bend. You can get +/- 5 degrees or better with one of these. </TD></TR></TABLE>
nice! thanks!
Old Sep 3, 2006 | 05:25 AM
Howitt's Avatar
Default Re: I need a tool that will help me figure out bend angles. (KFMRC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KFMRC &raquo;</TD></TR><TR><TD CLASS="quote">There are several manufacturers that make measuring tools like a faro arm for reverse engineering tubular assemblies. They are at least 35K.
Example
1/64 = .015625
1/32 = .03125
1/16 = .0625
the last 2 faro arms I bid on at auction, only went for about 5-7k. I want one but cant afford that much on a toy right now
jdmsohc2nr
Jan 29, 2008 06:25 AM
TurboSI56
Welding / Fabrication
Feb 20, 2007 04:33 PM
Want2race
25
Jul 21, 2006 05:10 PM
97spooncivic
Apr 2, 2006 05:39 PM
