Suspension & Brakes Theory, alignment, spring rates....
Need help connecting the tie rod end
Old Sep 2, 2006 | 11:35 AM
atg1290's Avatar
Default Need help connecting the tie rod end
I took the hub off to change the bj and now i have everything back together other than the tie rod end. Whenever i try to tighten or loosen the castle nut that fastens it down the whole assembly turns with it(almost like the a bj) I was just curious if this means something or if anyone has any tricks to get this thing done already. Thanks
Old Sep 2, 2006 | 06:48 PM
atg1290's Avatar
bump wanna get this done by tomorrow..
Old Sep 3, 2006 | 07:21 AM
Eddiebx's Avatar
take a hammmer and hit the tie rod upwards from the opposite side of the nut. then try and loosen the nut.
or if u have an impact wrench, pry between the knuckle and the tie rod and hit it with the impact.
Old Sep 3, 2006 | 01:34 PM
atg1290's Avatar
I tried almost everything so i decided to replace them since i almost replaced every suspension component..
Old Sep 24, 2006 | 02:47 PM
B18EG6's Avatar
Default Re: (atg1290)
Hey andrew-
How did you fix your spinning tie rod end? Mine is a bit loose and I dont want to install the knuckle is I wont be able to tighten down the castle nut on the tie rod.
Lemme know
MenaceDee
10
Mar 7, 2008 07:23 PM
HuskerHybrid
33
Dec 19, 2006 08:22 PM
atg1290
Sep 3, 2006 03:55 PM
SVOboy
11
Sep 18, 2005 05:09 PM
arcticblursx
Mar 29, 2003 01:00 AM
