00 civic... what will help me get some good numbers?
try searching next time... this has been covered 1435124564256234653452134521345 times but im not an ******* so here start there https://honda-tech.com/zerothread?id=335078
CAI and intake mani, good filter. Port and polish. Cams, valves, pistons. Adjustable cams for dyno/street tuning. And slightly advance your ignition timing. Leave the plugs and plug wire oem. It's probably the best you're gonna get. Raise the compression. Look on ebay for ideas on all N/A parts you can get. Good luck.
BTW you're looking at at least 2k for decent power where you could spend 800 for your homemade turbo and do the same thing... but each to his own.
nasirjones9mm
12
Mar 7, 2006 05:18 AM
or jus build the hell out of your motor
