what size oil line does everyone use for their oil inlet?
Old Sep 2, 2006 | 09:54 AM
sampol999's Avatar
Default what size oil line does everyone use for their oil inlet?
im planning on using a -4 line for my oil inlet to a greddy kit. old oil line was bad so decided to upgrade. all the fittings will be the same and will use a banjo fitting for the oil inlet. would this give me enough oil pressure to the turbo? i've seen others use -3 lines but some had oil pressure problems(too high). some one help please.
Old Sep 2, 2006 | 09:57 AM
DaveF's Avatar
Default Re: what size oil line does everyone use for their oil inlet? (sampol999)
-3 on any car ive ever built. never once a problem.
Old Sep 2, 2006 | 03:17 PM
Dunc's Avatar
BCICAN
Default Re: what size oil line does everyone use for their oil inlet? (dturbocivic)
Used -3AN with no problems...the turbo's seals went out after about 25,000 miles and 1.5 years I think it was. Now I have a -4AN line with the ATP Turbo .60 restrictor. No oil residue at all after about 8000 miles.
Old Sep 2, 2006 | 03:28 PM
MikeW's Avatar
Default Re: what size oil line does everyone use for their oil inlet? (AF-P Dunc)
-3 for most people but -4 with restrictor will be alot better for your turbo.....most hondas see up to 80psi or more of oil pressure and your turbo doesnt need that much...thus the need for the restictor with the bigger line......
Old Sep 2, 2006 | 03:47 PM
sampol999's Avatar
why would you need a restrictor if your running a bigger size diameter line with a banjo fitting to go with it? the greddy turbo runs a big diameter line with the banjo fittings with no problem. isnt the banjo fittings purpose is to restrict some some of the flow? thanks for the reply guys.
Old Sep 3, 2006 | 08:39 AM
B18C Turbo's Avatar
where do yuo guys buy these oil restrictors?
Old Sep 3, 2006 | 08:41 AM
DaveF's Avatar
Default Re: (B18C Turbo)
precision sells them.
Old Sep 3, 2006 | 08:53 AM
vaporboy12's Avatar
Default Re: (dturbocivic)
-4 with a oil restrictors
Old Sep 3, 2006 | 09:50 AM
B18C Turbo's Avatar
precision sells them, great help, show me where I can buy these please
Old Sep 3, 2006 | 12:50 PM
A.E Motoring's Avatar
i was using a -3an, did a firewall kit put a bigger line on, blew the turbo seals, make sure u get a restrictor for a bigger line
Old Sep 3, 2006 | 12:56 PM
btech's Avatar
Default Re: (SPNFEDEH)
yeah i also have a -4 line. its way to big and oil is leaking onto my downpipe and also car is smoking a lot.... blown seals?
i just purchased an oil restrictor and i don't have the fukin tools to take out my turbo to isntall the resrictor. the drak manfild is way too tight for my tools to get into.
can't find a decent offset wrench either.... bought a couple and the offset was way too much and didn't fit between the creeps....
Old Sep 3, 2006 | 01:02 PM
DRAGLS's Avatar
Default Re: (btech)
on my integra -3
on the supra a -4 with a .060 restrictor
on the celica a -4
Old Sep 3, 2006 | 01:09 PM
Hondacivicnut's Avatar
-4 AN with home made oil inlet restrictor here My turbo blew the seals without the restrictor
tuhboek
Jun 21, 2010 05:51 AM
South Bay Surfer
Jul 10, 2008 10:31 AM
4NBliss
Jul 25, 2005 09:07 AM
B20-T
Feb 12, 2003 03:04 PM
Blown90hatcH
Dec 26, 2001 11:26 PM
