::Need Help-car bogs once around 2-3k rpm., searched and tried everything::
Old Sep 2, 2006 | 08:12 AM
Esdelota's Avatar
Default ::Need Help-car bogs once around 2-3k rpm., searched and tried everything::
arite this is my setup. b20z block sleeved b16 head stage 2 cams, and skunk2 valves and springs. the other day i was lighting up my tires and bounced off 9200k. i ve done this plenty of times with no problems. so i did it the other day and after that my car would bog wit light throttle around 2-3k but after that car ran strong. once in awhle i would shut it off then it would run perfectly again. like every 2 on and off. the car would ether have that problem or not. so i checkd my plugs my plugs wer shot. so i changed my plugs and cap and rotor, didnt change the wires yet, but i still have the same problem. ive searched it up and tried everything. please help. thanks
Old Sep 2, 2006 | 09:48 AM
Esdelota's Avatar
Default Re: ::Need Help-car bogs once around 2-3k rpm., searched and tried everything:: (Esdelota)
bump...
Old Sep 2, 2006 | 09:50 AM
philosofy1's Avatar
what year civic? do you have any CEL's?
Old Sep 2, 2006 | 10:24 AM
Esdelota's Avatar
Default Re: ::Need Help-car bogs once around 2-3k rpm., searched and tried everything:: (philosofy1)
92...my only cel is o2 sensor
Old Sep 2, 2006 | 11:20 AM
Esdelota's Avatar
bump...sum1 gimee suggestions, thanks
Old Sep 2, 2006 | 11:31 AM
Esdelota's Avatar
check cels again...i got cel # 9 cyp. so wat should i do
Old Sep 2, 2006 | 04:37 PM
Esdelota's Avatar
bump
Old Sep 2, 2006 | 10:36 PM
Esdelota's Avatar
bummpppp
Old Sep 3, 2006 | 06:06 AM
Esdelota's Avatar
bumppp
Old Sep 3, 2006 | 10:09 PM
Esdelota's Avatar
any1?/
nonamedude
17
Mar 22, 2012 06:11 PM
punk_0333
Jul 17, 2010 10:28 AM
MrXclusivE
11
Jan 14, 2010 01:15 PM
a1320honda
Jun 10, 2009 11:22 AM
Ice-Nine
Jun 28, 2008 07:14 AM
