99 d16y8 motor-which crank pulley
Depends on what alternator you use. If you're using an EF alternator, they use a 3 rib belt so you would need an A6 crank pulley. Y8 uses a 4 rib belt so you would need the OBD2 alternator and plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6doorsentra »</TD></TR><TR><TD CLASS="quote">i have a 99 d16y8 motor, but i dont have the crank pulley..which crank pulley is compatible with this motor?</TD></TR></TABLE>
a Y7 pulley will work - the earlier pulleys like D16A6 will not work on the Y8 - they won't clear the CKP sesnsor
EF8 D-UNIT
Jan 10, 2006 04:16 PM
