Crankshaft pulley fell off.
Old Sep 2, 2006 | 02:51 AM
EnSAn's Avatar
Default Crankshaft pulley fell off.
I got lucky and that's all that happened. So now i need the bolt washer and the key. Would they have what i need at the autopart store? Or will I have to goto a Honda dealer? need some help ASAP my car is stuck at work and well i'd hate to spend the weekend with a broke down rex Also what else should I check for. Don't know if anything might have gotten messed up. I'm not tossing in CEL's just the Bat light. I have a new Alt belt. So let me know if there is anything else I should do since.. well... it's off.
Old Sep 2, 2006 | 03:31 AM
JJ's civic's Avatar
Default Re: Crankshaft pulley fell off. (EnSAn)
i just go to the junkyard get a new pulley bolt washer and key. the reson for the pulley is because it may not be straight anymore
Old Sep 2, 2006 | 03:45 AM
crxnj's Avatar
Default Re: Crankshaft pulley fell off. (joeny12985)
just get a new bolt,washer and keyway from honda,,at my local dealership its only about $5.xx for the bolt,$3.xx for the washer and $2.xx for the keyway....trying to get a crank bolt of a junkcar will be a pain in the ***.......you'd want a new crank pulley to ,,,should be around $60-$70..sorry it happened to you but since all that ***** off might as well change the timing belt,waterpump and tensioner..up to you though
Old Sep 2, 2006 | 03:52 AM
boston's_rex's Avatar
would be easier to go to dealer and pay $10 if its any thing like junkyards around here. did you lose the thrust washer ? is the pulley damage?
Old Sep 2, 2006 | 10:42 AM
EnSAn's Avatar
Default Re: Crankshaft pulley fell off. (boston's_rex)
So somthing a little funny on what happened. So i just got back from honda and picked up the bolt and key. Drove back to myplace to do the oil on the civic before i drove out and fixed the rex. took off the tire tossed down the lug nut RIGHT NEXT TO THE crankshaft pully BOLT. That means I drove for a day with out the nut before it fell off. Just glad it fell of a block away from work well off to go fix it.
Old Sep 2, 2006 | 11:49 AM
Loserkidwac's Avatar
I had it happen to be before, got on the high way and started accelerating and bam the battery light cam one It was right after i did my timing belt too, I put the Key in verticall and not horizntal or whatever and it worked its way loose ...Hey we all learn from out mistakes but yea I was lucky like you that it didn't damage anything else and the pulled ended up sitting on the radius rod and was in good shape still when I pulled off the hgihway good luck
BobbyRodriguez
Welding / Fabrication
Jan 8, 2011 11:31 PM
barrera
Oct 11, 2010 07:17 AM
freshley
Jun 26, 2006 01:19 PM
Cuong-nutz
Aug 2, 2005 09:09 AM
NatedoggAZ
Mar 18, 2004 08:56 AM
