What kind of plugs????
Old Sep 1, 2006 | 07:15 PM
hondachris1994's Avatar
Default What kind of plugs????
What plugs are good for an all motor setup with cams and pistons?
Old Sep 1, 2006 | 07:17 PM
Default Re: What kind of plugs???? (hondachris1994)
stage 2 cams and JE 11.1 pistons to b exact in a b16
Old Sep 1, 2006 | 07:45 PM
xNOBOOSTx's Avatar
NGK Iridiums.
Old Sep 1, 2006 | 07:48 PM
Default Re: (xNOBOOSTx)
thats what I got now, I was just curious if that was gd for an all motor setup
Old Sep 1, 2006 | 08:04 PM
1234567899876543211230's Avatar
it should be =]
Old Sep 1, 2006 | 08:28 PM
Default Re: What kind of plugs???? (SleeeeepyDX)
thats what I thought
Old Sep 2, 2006 | 07:49 AM
I heard the iridiums dont come gapped rt but there supposed to b pregapped anyone else heard that?
Old Sep 2, 2006 | 08:58 AM
96-EJ6 B18C's Avatar
Default Re: (hondachris1994)
If your ordering them for your specific application and the part number ends in -11 that means they are pregapped to 1.1mm which is factory spec.
Old Sep 2, 2006 | 01:55 PM
Default Re: (96-EJ6 B18C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">If your ordering them for your specific application and the part number ends in -11 that means they are pregapped to 1.1mm which is factory spec.</TD></TR></TABLE>does it matter when the motor has cams and pistons to use that same part #?
Old Sep 2, 2006 | 02:07 PM
SkoundrelUSA's Avatar
cute little bastard
NGK V-power BKR7E-11 gapped to .035
most N/A guys use those. including myself
Old Sep 2, 2006 | 02:08 PM
Syndacate's Avatar
With such little upgrades as that:
NGK...regular ****** standard plugs...no extra gapping, no platinum or gold or any other extra ****...regular NGK's for a B16 will be plenty good enough...
Old Sep 2, 2006 | 02:11 PM
draztk_tendncies's Avatar
Default Re: (Syndacate)
ngk iridium's suck *****
Old Sep 2, 2006 | 02:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">With such little upgrades as that:
NGK...regular ****** standard plugs...no extra gapping, no platinum or gold or any other extra ****...regular NGK's for a B16 will be plenty good enough...</TD></TR></TABLE>that was just part of my upgrades port and polish head 1mm oversized valves, MSD dizzy with coil, and every bolt on that u can name of
Old Sep 2, 2006 | 02:22 PM
Default Re: What kind of plugs???? (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">NGK V-power BKR7E-11 gapped to .035
most N/A guys use those. including myself</TD></TR></TABLE>I heard those were pretty good how much are those a piece?
Old Sep 2, 2006 | 02:26 PM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">I heard those were pretty good how much are those a piece?</TD></TR></TABLE>
I bought 8 at Pepboys for $16
Old Sep 2, 2006 | 02:27 PM
I bought 8 at Pepboys for $16 </TD></TR></TABLE>do they come pregapped?
Old Sep 2, 2006 | 02:43 PM
sohctodohc's Avatar
Default Re: (draztk_tendncies)
do you have any proof of this? or you just passing on misinformation? let me guess you run bosch
Old Sep 2, 2006 | 03:35 PM
Default Re: (sohctodohc)
i work at pepboys, im gonna find out tomorrow
Old Sep 2, 2006 | 04:29 PM
7's are probably a bit overkill for an N/A setup, that is the exact part number we run in boosted setups, but everyone has their own preference, honestly I have run several different heat ranges and it doesn't seem to make any real difference.
Black R
26
Dec 20, 2006 10:21 PM
dpine
10
Nov 26, 2005 09:28 PM
ALL MOTOR EF8
Sep 22, 2004 09:24 AM
fukaintmuven
Jan 10, 2003 08:28 PM
fukaintmuven
Jan 10, 2003 07:28 PM
