valves bent? vid included
Old Sep 1, 2006 | 04:48 PM
JSpekBB4's Avatar
Default valves bent? vid included
heres a vid of the sound my cars making, someone said it sounds like my timing is off another one said my timing belt is broke.... and than someone said that if it is my timing belt, than my valves are def bent.... if I put a new timing belt and reset the timing should it still start even if the valves are bent?... and whats the chances of my valves not being bent? hit me back please... heres the vid
http://media.putfile.com/Prelude-Starting-Problem
Old Sep 1, 2006 | 04:52 PM
darkspector2.0's Avatar
if you're timing belt has broken... then your valves are f'd... your car will not start with a broken belt.
Old Sep 1, 2006 | 04:54 PM
JSpekBB4's Avatar
Default Re: (darkspector2.0)
what if it's not broken just not set right? and I know it won't start with a broken one, I mean if I put a new one on and reset the timing... I know my powersteering belt spins..... which is connected to the crank that the timing belt is on, does that mean the timing belt is still on there?
let me explain how this happen, started my car drove around for a lil bit after i put some bigger rims on my car, parked it, it ended up snowing so I didn't start the car for 4 days, when I went back out there to start it, it was still really cold outside and icey, turned the key it didn't even try to start, just made the sound it's making now
Old Sep 1, 2006 | 06:13 PM
JSpekBB4's Avatar
Default Re: (JSpekBB4)
any other help?
Old Sep 1, 2006 | 06:26 PM
kulrevon's Avatar
ok well first of if this is an stock h22. the only time the h22 is inteference is when you are in vtec. so if the timing belt broke at start up you probably did not mess up valves.
take off the valve cover and check the timing belt to see if its intact.
Old Sep 1, 2006 | 06:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
The belt is probably still on there what happens a lot is the teeth shear off of the belt. Just because your belt broke DOES not guarantee your valves are bent especially since your engine wasnt running.
Old Sep 1, 2006 | 06:32 PM
JSpekBB4's Avatar
Default Re: (cb7-R)
yeah I have a f22a1 sohc non vtec, I'll take it off tomorrow and let you all know, I have a new timing belt anyways, just in case, no way to tell if the valves messed up, just by taking off the valve cover right?
Old Sep 1, 2006 | 07:20 PM
99LudeDude's Avatar
if you take the vc off, and take out the spark plugs, remove driver's side wheel, then have a friend turn the crank pulley you will see the valves moving up and down. The bent ones will move a lot more than the others. Don't forget to disconnect your neg. cable from the battery
Old Sep 1, 2006 | 07:24 PM
JSpekBB4's Avatar
Default Re: (99LudeDude)
took the vc off belt is snapped.... someone said since the car wasn't running nor did it try to turn over, my gears were prob frozen and wehn i turned the key and it tried to crank it just pulled the timing belt tight and snapped it... sound logical? which prob means the valves won't be bent since it never started right?
Old Sep 1, 2006 | 07:53 PM
99LudeDude's Avatar
you hope.... still you should check before you start the car, so you don't bend all of them. Make sure to time your engine correctly (all marks to tdc) before you start the car also, or else you'll bend the valves. Then, you can buy a timing gun from Autozone for like $60, use it once, and return it.
Old Sep 1, 2006 | 08:18 PM
JSpekBB4's Avatar
so hook up the timing belt put a socket on the crank and turn it and see if the valves move and how much?
udog1125
Sep 14, 2016 03:15 AM
woodin
Apr 8, 2008 09:26 AM
JSpekBB4
Sep 5, 2006 08:02 PM
b20integrapower
Mar 19, 2006 02:34 PM
AK94GSR
May 10, 2002 09:39 AM
