speedometer needle messed up?
Old Sep 1, 2006 | 04:38 PM
hamadiscool's Avatar
Default speedometer needle messed up?
I just came back from austin and like 2 mins before i got home my D4 (auto) light started flashing and my speedometer needle started hesitating or sometimes went to zero while driving....WTF!?!?! I just got on the gas a little to overpass someone nothing extreme. Can someone tell whats wrong? I will try to post a video later on. Thanks
Old Sep 1, 2006 | 05:10 PM
Default Re: speedometer needle messed up? (hamadiscool)
by the way, its a 5th gen 98 if it helps i wanna cry...
Old Sep 1, 2006 | 07:21 PM
99LudeDude's Avatar
uh-oh... get some loot together for a tranny swap. The evil SS gremlin strikes again. Your tranny is dying. swap in a manual.
Old Sep 1, 2006 | 08:06 PM
xplyboigurlx's Avatar
i had that problem a couple mths ago..it was ignition switch..haha
Old Sep 1, 2006 | 08:49 PM
M2B4's Avatar
Default Re: speedometer needle messed up? (xplyboigurlx)
how many miles are on that tranny?
Old Sep 1, 2006 | 08:58 PM
Default Re: speedometer needle messed up? (M2B4)
not sure, i got the car with 127k and now it has 134k. Tranny seems to be fine. just reset the ecu...seems to work fine now but not sure if it fixed it for sure...any comments? thanks
Old Sep 2, 2006 | 09:46 AM
Honda Sport's Avatar
1st rule of thumb, ALWAYS ALWAYS pull the code before clearing it so you can check up on things on the car.
if it drive's fine, then I say just keep driving and see if it ever comes back. make sure you pull the code if it ever pops back up.
Old Sep 2, 2006 | 11:43 AM
Default Re: (Honda Sport)
but the cel didnt go off...interesting
Old Sep 2, 2006 | 01:48 PM
Default Re: (hamadiscool)
Ok the cel went off today and the code i got was 70 and i searched and this is what i got: "Automatic Transmission malfunction with the automatic transmission controls"
and also when i was checking the code the D4 light flashed quickly 4 times. Am i screwed or is there hope for me? Thanks
Old Sep 2, 2006 | 03:12 PM
help please
Old Sep 2, 2006 | 06:42 PM
I really think now that my speed sensor thing is broken since code 17 (vehicle speed sensor) is flashing now, does anyone know how much a new one costs and where it is located on an engine? I would really appreiate, thanks
Modified by hamadiscool at 8:28 PM 9/2/2006
Old Sep 3, 2006 | 06:23 AM
ANYONE!?!?
Old Sep 3, 2006 | 06:57 AM
roller3804's Avatar
It probably is the VSS. You could go look at on the car and see if you notice anything wrong just by looking. Its on top of the tranny and its got a sort of diamond shaped plate with two small bolts holding it in. It probably needs replacing.
http://www.hondaautomotiveparts.com
I would try and find ones used or something though.
Old Sep 3, 2006 | 09:42 AM
Default Re: (roller3804)
Ya that was the problem. I had an extra auto lying around from last prelude and i just swapped it. Worked like a charm. Thanks guys now if i can only find an o2 sensor...
elliascool
Mar 23, 2011 03:06 PM
ElCapitan(BB6)
Sep 9, 2006 06:12 AM
Mik3
Mar 28, 2006 07:46 PM
preludeguy_92
May 11, 2005 08:16 PM
BlkChryKord
Feb 27, 2005 07:13 PM
