I need help on setting my VAFC
Old Apr 28, 2002 | 07:30 AM
JdoggsGSR's Avatar
New User
Default I need help on setting my VAFC
Hey was up guys i have Skunk2 stage2 cams, skunk2 cam gears, Skunk2 intake manifold, ported and polish head, 3 angle valve job, springs, and retainers, what should i set the vtec too? Right now i set it at 5800. and my car is running real rich?? Hook me up on some info
Old Apr 28, 2002 | 08:17 AM
evo's Avatar
evo
New User
Default Re: I need help on setting my VAFC (JdoggsGSR)
Everyone will come up with same answer(go to dyno).
Old Apr 28, 2002 | 08:33 AM
I Drive A Saturn's Avatar
Default Re: I need help on setting my VAFC (evo)
yup, every car is different. even if another gsr has the same mods as yours, a paticular VTEC setting that some dude is running won't be optimal for your car. go to a dyno, get it professionally tuned.
-jeremy
Old Apr 28, 2002 | 10:09 AM
JdoggsGSR's Avatar
New User
Default Re: I need help on setting my VAFC (I Drive A Saturn)
Ok but with my set up should i be running rich i thought if anything i should be running lean???
Old Apr 28, 2002 | 10:11 AM
Chubz's Avatar
DYNO
Old Apr 28, 2002 | 10:14 AM
JdoggsGSR's Avatar
New User
Default Re: I need help on setting my VAFC (RLukas)
So i should take it to a dyno right iight kool thanks but i still think i should be running lean.. Where in NJ i can take my car to get it on a dyno, and how much will it cost ruffly??
Old Apr 28, 2002 | 10:17 AM
gsrvx's Avatar
New User
yea dude...do ur motor a favor and take that thing to a dyno. Well, make sure the tuner knows what they're doing. It'd be a shame if you didn't dyno it with all that money spent modifying the engine. Keep us updated on ur numbers!! How do you like the skunks man?
-Rod
Old Apr 28, 2002 | 10:32 AM
JdoggsGSR's Avatar
New User
Default Re: I need help on setting my VAFC (RK)
I love them ***** man first what i did was just ported and polish the head, did the 3angle valve job, skunk2 intake manifold, skunk2 cam gears and had the stock cams to see if i had felt a difference and set the cam gears at 0,0 it was nice as hell but the only thing was i had a dead spot around 4500 so i put the cams in and man i felt even a bigger difference and the vtec just screamed it was loud as hell, so after like 2weeks i baught the VAFC and after i set the vtec to around 5800 and there was no more dead spot at 4500 it just pulls but the only problem i have is my car is running rich and because of it running rich i using madd oil im adding oil like every 3 days plus by me beating my on my like all day but anyways the cams are worth it..
handa
Oct 2, 2005 07:18 PM
black sohc civic
Sep 30, 2003 05:59 AM
myh22
Sep 17, 2003 09:59 AM
JdoggsGSR
Apr 28, 2002 01:13 PM
RedTeg95
Apr 25, 2002 07:45 PM
