Do I need an AFPR if I have a Walbro 255? (EK w/GSR)
Old Sep 1, 2006 | 04:05 PM
boostd92's Avatar
Default Do I need an AFPR if I have a Walbro 255? (EK w/GSR)
I've got about 1000 miles on my b18c1 swap in my 2000 hatch.
I believe the car has a Walbro 255 pump in it. The preivious owner sold me the shell with goodies.. he just pulled the motor, and that motor was making 385/515whp. I can hear the whine of the pump at idle, as well.
Anyway, i come from DSM and toyota land... it's quite common to get higher fuel pressures at idle when using stock rail/fpr and a 255 pump... the fuel return on the stock fpr is just too small to relieve enough fuel to maintian stock fuel pressure.
I'm getting quite a bit of fuel staining on the rear bumper, and my WS2 tip doesn't even come out past the bumper. I'm not running a cat, and I do see quite a bit of dark smoke on WOT blasts (I know some is normal, not sure how much).
I guess my question is, does a stock '01 GSR motor's FPR have the capability to return enough fuel from the rail to relieve the high pressure of a Walbro 255lph pump at idle? Do I need to get a fuel rail and AFPR to obtain stock idle A/F's?
Thanks!
Old Sep 1, 2006 | 04:10 PM
Syndacate's Avatar
Default Re: Do I need an AFPR if I have a Walbro 255? (boostd92)
It really should be able to.
Old Sep 1, 2006 | 04:19 PM
boostd92's Avatar
Anyone else? I haven't pulled the FPR off to examine the fuel return outlet, but I know it's common on my 2.2L stroked 3SGTE and my old 2.0L DSM... seems logical to me that a 255lph on a 1.8L would cause overrun..
I searched, but with inconclusive results. Thanks!
Old Sep 1, 2006 | 05:00 PM
nsxmatt's Avatar
Default Re: (boostd92)
The walbro doesn't add a ton more pressure but it does send more volume. Your car will run slightly richer with the walbro, best bet may be to throw a stock Civic pump in it as they are fairly cheap.
Old Sep 1, 2006 | 05:45 PM
FuNkDrSpOt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostd92 &raquo;</TD></TR><TR><TD CLASS="quote">I've got about 1000 miles on my b18c1 swap in my 2000 hatch.
Thanks!</TD></TR></TABLE>
When I dyno'ed my JDM B18c GSR in my Ek with a stock fuel pump and I was going 18:1 lean when I was @ WOT. When i got a HP Walbro 255 pump it's a noticable difference.
Your car won't run richer @ closed loop. During WOT, you'll have plenty of volume @ Vtec.
I haven't had any problems with fuel since.
Modified by FuNkDrSpOt at 1:41 AM 9/2/2006
Kr4nG
Sep 28, 2009 02:31 AM
schpiel
Jul 10, 2008 01:08 PM
boostd92
Sep 2, 2006 04:00 AM
UNKNOWN_MEMBER
Aug 16, 2005 01:29 AM
Lysawy
Jul 28, 2003 07:45 AM
