d16z6 feels like it cuts out before 7k any ideas?
Lately my motor hasnt let me redline it. feels like it gives out right before 7k.just started happening. any ideas or suggestions would be great
Bump... need help vtec is not engaging also.Im throwing vtec oil pressure code. tried rewiring to ecu, checked oil, cleaned out vtec solenoid screen. Throws code when i should be in vtec and then when i restart my car its gone. When i removed vtec solenoid no oil came running out? is this right? is my oil pick up clogged? any help is appreciated this is driving me crazy! next step looks like im taking of the oil pan.
No im not trying to go past 7 feel like i got a rev limit at about 6500/6800 my stock redline is 7200 is this because vtec is not being engaged?
stock redline is 7200 but the motor stops making power at 6800.
are any mods done to the engine??? you might have a clog somewhere causein the low oil pressure
Bone stock d16z6 Oils good. rewired everything to make sure. Seem to throw code in high rpm in 3rd gear.
aite thanks for the help. I guess ill be taking off the oil pan. How do i know if the pick up is clogged? any suggestions on way to unclogg it. First time taking the pan off. and do i need new gasket or can i use liquid gasket?
if oil pickiup in pan was clogged you probly would still be walking back home, or waiting for a tow truck. Trace the oil feed and return lines from solenoid to where they connect/disconnect, and clean them out, if theat don't work, go further down the lines, etc etc.
(clean out with compressed air or something, no water or cleaners, unless maybe its oil additives or oil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5g »</TD></TR><TR><TD CLASS="quote">your prolly low on turn signal fluid</TD></TR></TABLE>
wtf!!!!!!
are you 4 real?
wtf!!!!!!
are you 4 real?
hell ya dude that ***** serious i had to get a mechanic to do my **** i didnt have the right sized flux capacitor but he did it only cost 700$ and the power i got was amazing i really felt it in the butt dyno
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5g »</TD></TR><TR><TD CLASS="quote">hell ya dude that ***** serious i had to get a mechanic to do my **** i didnt have the right sized flux capacitor but he did it only cost 700$ and the power i got was amazing i really felt it in the butt dyno</TD></TR></TABLE>
ok now ur jus beening a dumbass
